Inverse Lighthouse Beam Effect on Bright Stars with Tak FSQ 85-EDX
19 replies1.4k views
Bruce Donzanti avatar
I've been enjoying my Baby Q but I have noticed on some bright stars (example, Alnitak on the image below), the so-called "inverse lighthouse beam" pattern which has been attributed to vignetting as a result of the Petzval design.  My setup is the Tak FSQ 85-EDX with the 1.01X field flattener designed for this scope, along with the ZWO ASI6200MM Pro.  The flattener is said to support sensors of size APS-C or smaller, so maybe it is the larger 6200 sensor causing this???  Backfocus is correct and tilt minimized.  I have seen this effect with two different Ha filters.  I have seen this effect on a number of images on AB by others, but other images seem to have tempered its appearance.   Any suggestions on how to reduce this look on bright stars would be appreciated.
Dan Brown avatar
Bruce Donzanti:
I could be wrong but I would guess that is a diffraction pattern from a lens cell nut. I see the same effect on my camera lenses.
The only way I have dealt with the issue is in photoshop. I make a circular selection centered around the flare. I then 'layer via copy'. Set the blending mode to lighten. Slowly rotate the selection till issue is resolved.
Hope that helps.
Dan
p.s. Nice image.
matthew.maclean avatar
In this image, Alnitak is near the outside of the frame. Does the same thing happen if it is in the frame center?
JohnHen avatar
Hello, the effect is typical for the FSQ. My dealer told it is a 'signature' of the scope. It appears irrespective of filter. Here
https://www.astrobin.com/full/sha3ff/C/?mod=&real=
is a FF of mine on an OSC camera. The effect is very prominent on both sides of the frame. Anyway, I never remove it.
CS, John
Die Launische Diva avatar
This effect is also apparent with the Samyang/Rokinon 135mm f/2 lens when used wide-open. I've also seen the same effect in high-end Vixen refractors and other camera lenses (Canon and Sigma). I also don't bother with it. Some Samyang owners either stop-down the lens by using the diaphragm or a step-down ring.
Arun H avatar
Die Launische Diva:
Correct. Seen this with a few of my Canon lenses. Always attributed it to diffraction caused by some kind of obstruction. Just learned to live with it. Not particularly bothersome.
Jay Hovnanian avatar
Bruce, I believe this "effect" is called Aperture Vignetting.  I can't comment as to why it appears as such, but have experienced the same with my FSQ-85EDX when the Dew Shield is (close to or) fully out (extended).  You can see it in my recent Pleiades in December image.  I tested a cure last week; pulled the Shield back (retracted in) somewhat and the effect diminished greatly ... and I know that I can retract it completely in (which I will do when shooting from a dark site with no significant sources of stray light).  Shooting at a light polluted site may be more of a challenge requiring the shield to be out (at least) somewhat.  BTW, I did my testing in my Bortle 6 driveway and at a Bortle 4 site.  Hope this helps, Jay
Thorsten avatar
Hi Bruce,
first, I would like to briefly explain (very simplified) where the effect comes from. Everybody knows the diffraction pattern of some typical apertures in astrophotography. So, the diffraction pattern of a round aperture is the Airy disk. The diffraction pattern of a Newtonian telescope is a superposition of the Airy disk with the typical spikes by the spider od the secondary. Also pretty much everybody knows the diffraction pattern of the Bahtinov mask. I have shown all three in the first figure. The diffraction pattern (below) is the 2D Fourier transform of the aperture shape (above).
Refractors should actually always show each star as an Airy disk. However, the telescope does not consist of only one lens, but usually of several lenses (front lens and reducer for example). In addition there are apertures like the dew shield (like Jay said before). If a star is not imaged on the optical axis, but further out at the edge of the image, then the projection of the telescope aperture is no longer a circle, but a superposition of two circles. I have tried to show this schematically.
The Fourier transformation of this aperture shape then results in the inverse lighthouse, as in your image.
The whole thing might be handeled in the image post-processing somehow (I can't do that) or it can be avoided from the beginning, if the star is not too far away from the optical axis or if the outermost projection of the aperture is circular by a clever arrangement of apertures. But the latter means: Either you use small camera chips or increase the f-stop number. But nobody really wants that. I hope I was able to help out a little.
Clear skies
Thorsten
Thorsten avatar
Hi Bruce,
sorry, nice image by the way smile
Clear skies,
Thorsten
Thank you, Thorsten, for the education.
Bruce, Yes - that is a very fine image.
I still love my Baby-Q ….
Wow- lots of thorough and thoughtful responses.  Thanks to all for your experiences and suggestions.  Based on reviewing all of this, I am quite happy to ignore the informally described "Inverse Lighthouse Beam Pattern"/Butterfly Effect smile as I love the Baby Q.  It produces magnificent wide field views with the full frame sensor.  However, it is interesting to learn about the science causing the aperture vignetting.  I did try using various tools in PixInsight to help temper it, but frankly, it is not worth the effort.  And some of the other potential options, assuming they would even work, would only lead to other issues in my dewy, LP skies.
Thank you all once again for the feedback on my image and help in understanding this topic.
Clear Skies to all!!!
Bruce
Bruce, when all else fails, the Healing Brush in Photoshop can do wonders ....
Parag Batavia avatar
I'm just about to pull the trigger on buying an FSQ-85EDX and 6200MM - so great to find this thread.
Anyone here with any experience with PixInsight's StarNet++ or StarExterminator on stars that have this lighthouse effect? Are they properly recognized and removed?
Parag
Parag Batavia:
Parag
Yes- StarXterminator does recognize and remove it almost perfectly when used on the linear image.
Parag Batavia:
Parag
I wouldn't make such a serious decision based on the performance of some software which are under constant development/improvement. Both the telescope and the CMOS camera you consider buying are well-established performers in the astrophotography community. Some astrophotographers may even consider a sacrilege having such a high-end hardware combo and rely on StarX/Starnet for obtaining quality images
Die Launische Diva:
Parag Batavia:
Parag
I agree.  The scope with a decent CMOS camera (as mentioned previously in this thread) are a wonderful combination.  No need to judge its use based on any pre- or post-processing software.  In fact, I have been very pleased with my images even before minimal processing under my Bortle 7, LP skies.
Die Launische Diva:
Parag Batavia:
Parag
Hah! Fair point... I've got a workflow that I use - and always willing to change it, but if existing methods failed dramatically, then that would be good to know. I'm finally at a point where I think my processing has outpaced my (current) equipment, and now I want to go the other way and have my equipment outperform my processing - and improve my processing...
I've been spending days going back and forth on telescope / camera combinations, taking into account what is available, etc. Finally settling down on the FSQ-85 + 6200 - and looking on here to find examples of that combo, to confirm that you really can use the FSQ-85 with a full frame sensor.
Parag Batavia:
Well- there are many of examples on AB to help you decide.  Best of luck in your choice.
dkamen avatar
Well, if (some) Taks have the same issue maybe I should reconsider using the Zenithstar 73II which has been collecting dust for almost two years smile
[RCC] Second light with Tak Baby Q
Hello all, I've just completed my second image with my new setup (Tak Baby Q with ASI533MC-Pro on CEM70) and used APP for the first time for stacking and initial stretch. I'm happy with the result but would like some feedback from the experts...
Inverse Lighthouse Beam Effect on Bright Stars with Tak FSQ 85-EDX — discusses Takahashi scope issues relevant to Baby Q user
Sep 4, 2021
Best max. 400mm scope at the moment
Hi guys,I just sold my FRA300 from Askar because I wasn't too happy with it. There was chromatic aberration (CA), and the stars in the outer third of the field were elongated and too large. So, I’m looking for a new scope in that range. I’m think...
Discusses Petzval design issues including vignetting and optical aberrations.
Oct 17, 2024
Which Petzval wide field refractor?
I’m thinking about replacing my 72ED refractor with something nicer so I’ve started looking at what I might like instead. I’ve decided on a petzval astrograph of some description but can’t decide what focal length to go for. My 72ED is 420mm and ther...
Directly addresses Petzval wide field refractor selection and performance characteristics.
Nov 6, 2024
