L-enhance vs STC Duo
4 replies227 views
Thanos avatar
Hi all. I have the stc duo narrowband filter and I am relatively happy with it. Wife wants to give me a gift and I was thinking of asking for the l enhance filter. Is it worth it? It is triple pass instead of duo I think and gives less halo around stars? Any advice welcome. I shoot ln bortle 2 skies
Waste of money in Bortle 2, if you ask me. Go fo the L-Extreme with focal ratios greater or equal to f/4 instead. Worth having to allow shooting with Full Moon.
Thanos avatar
Thanks for the advice. I shoot usually at f2.8 with a samyang 135. Any other filters you would advise ? I mainly shoot nebulas 👍
You could put it in front of the lens, with the right adapter. That would sort out any bandshift issue and also most of the halos as well. There are other 2-bands adpated to fast optics but I do not use them.
Joe Linington avatar
The IDAS NBZ is a bit wider than the L-Extreme but not an issue under your skies, the advantage is less halo from what I have seen here and it is more tolerant of high speed systems like your f/2.8. Some people have reported issues with the L-Extreme below f/4 but it seems to be variable.
A PSA/Rant/Warning/Opinion on CLS Filters, Light Pollution Filters, and Tri or Quad Bandpass Filters
Summary: These products are misleading in their marketing and do not return a result that is worth your money. This is intended to be a warning message that I'd copy/paste to people considering buying one of these filters, but I figured I'd p...
Warning about filter marketing and effectiveness; directly relevant to filter purchase decision.
Dec 3, 2024
The cause and the elimination of halos around stars with some duo-narrowband filters
I had this problem with two of my dual narrowband filters: huge halos around some stars, although I noticed that the affected stars are not always the visually brightest in the image. I also noticed in the last series of photographs that it seems to ...
Discusses halos around stars with duo-narrowband filters; addresses author's specific concern.
Sep 22, 2024
