AsiAir Pro compatibility with Nikon D3500
9 replies389 views
Nikolas Konstantinou Kakopsitos avatar
Hello, I was wondering if someone tried to connect the Nikon D3500 DSLR with the AsiAir Pro. And if so, how did you do it?
​​​Thank you in advance and clear skies!
Connor Kessler avatar
As far as I know, currently the ASI Air Pro only works with ZWO products that are compatible with its ecosystem.
Maurice Toet avatar
I use an ASIAIR Pro in combination with a Nikon D810a, so I guess you’ll be able to connect other Nikon DSLRs as well.
@Maurice Toet  I know that the ZWO has a list of the compatible DSLR cameras but I can't find any information about the D3500.
Thanks for the reply 😊
Nikolas Konstantinou Kakopsitos:
I never knew this, this is actually really good to know. I've only ever used CMOS cameras for the hobby and I was always told that nothing but ZWO products worked with the Air.
Jonny Bravo avatar
Multiple Canon and Nikon cameras work with the ASIAir... it's right on ZWO's website:
This is for the current ASIAir Plus... regarding the OP's question, the D3500 isn't on the supported list on this or the ASIAir Pro (older version).
Concise
Jonny Bravo:
Thank you for the information 🙂
dkamen avatar
It's untested, not unsupported.
As far as I am aware, ASIAIR uses INDI under the hood and that supports the D3500, basically is the same driver as any other Nikon DSLR.
Stellarmate Plus also lists it as fully supported.
Thank you much. Hopefully I will try it tonight
What about the Canon M200 or mirroless cameras in general? does anyone use them with AsiAir Pro?
