NighttimeskyGuy avatar
Hello all and Happy Thanksgiving !
Now that I think I have a handle and cmos camera gain, I could sure use some pointers on camera offset. I’m a ASI 1600 mono cooled user and I can’t find how offset should effect my images or how they might be better with a higher or lower offset .
Thanks
Shawn Killian avatar
Hi , I image with the qhy 163 m, which is the same as the asi 1600, and I use different gains depending on the target or filters used, but I use the same offset for all my different gain settings, and I haven't had any problems. Hope this helps, clear skies!
dkamen avatar
Hello all and Happy Thanksgiving !Now that I think I have a handle and cmos camera gain, I could sure use some pointers on camera offset. I’m a ASI 1600 mono cooled user and I can’t find how offset should effect my images or how they might be better with a higher or lower offset .
Thanks
Offset is just a constant (DC) current added to your signal before it gets recorded. Whereas gain is voltage amplification, i.e. a
multiplicative factor.
In very simplified and somewhat inaccurate terms, the end signal that gets recorded by the sensor is:
end signal = (incoming signal X gain) + offset
Actually the bit that says (incoming signal X gain) is a gross oversimplification because real gain is decibels, not absolute number.
Doesn't matter here, let's just assume gain is expressed as the equivalent multiplication constant instead, and let's focus on offset
which is just an added constant.
So, offset is the minimum signal which will be recorded by your sensor if the incoming signal is zero. Basically, open any picture in any image editor and try adjusting the brightness,this is what offset does and as long as you don't clip in either side the transformation is completely reversible. Why don't we set offset to
zero, or as close to zero as possible? Because noise (random +- in your signal) can result in negative values. Also, if the lower values you record are e.g. around 5, a noise of +-2 affects them a lot, almost 50% of the signal. If you add an offset of 50, suddenly the noise becomes 2.5% of the signal.
I haven't really touched the default offset of my 183MC, but from the above analysis (and the fact that I've never had to touch it) I am assuming any moderate value is equally good, does its job which is to keep your lowest data values at a reasonable level, and can be subtracted in post processing. Stick with that value
so that images from different sessions are easier to combine, although most modern integration algorithms will equalize offsets for you anyway.
The only case where offset will have an important impact is if you set it so high it will blow  parts of the picture to white. This is
something you don't want.
Gain is a far more important setting because it directly affects the dynamic range of your image.
D.
Helpful Insightful Engaging
Great info, thank you very much !
How do you deal with camera Offset?
Hello folks, until now, I did not really care about the offset settings of my ASI183MM camera. I just took the images setting exposure time and gain. Then, an almost unmentionable comment from amother user made me think of using the offset parameter ...
Directly addresses camera offset settings for ASI camera models like yours.
Aug 8, 2021
New to Voyager
New to Voyager, might need some help on certain tabs.. thanks ..
Relevant - camera settings guidance for Voyager users with ASI cameras.
Mar 5, 2019
Hollow stars and coma problem
Hello, I have an F/4 Newtonian with a ZWO ASI 1600 + Filter wheel + coma corrector. Before the ZWO ASI camera I had a Canon 600D that always gave me nice round stars up to the corners. Since I started using the ZWO Camera I started getting these sort...
Discusses ASI 1600 camera settings and image quality optimization techniques.
Mar 1, 2021
