Would you be leaving this alone or would you of cleaned it long ago ...
thnks for all your replys.
The scope is always covered when not in use.
I have recently installed a fan which helps with condensation so hopefully that will help in future.
Collimation.. the mirrors already un-installed and im comfortable with the procuedure for this scope.
My main reason for the question was if i was being overly anal in wanting to clean it.
I cant see how in its current state it wouldn't be degrading images?! but was curious what the consensus would in terms of if its current state met the threshold.
andrea tasselli:thnks for all your replys.
I have run one mirror for 10 years before deciding to clean it up. Reality is it takes an awful amount of dirt to visibly degrade the images and frankly I cannot be bothered to get everything down because of a bit of fluff. Shining light across a mirror surface might seem to highlight a lot of stuff deposited over there but one should resist the urge to make it look pristine as you may well run the risk of ruining it far more than any gain you might achieve.
