Photographing with a full Moon with the L-Enhance filter. Recommended?
13 replies680 views
Tomás Andonie avatar
Hi everyone.
Likewise, as you read in the title, I ask you if it is possible to photograph nebulae with the L-Enhance filter on a night with a full or almost full moon.
I know it's not recommended, of course it won't be the same as a night with a new moon, but I want to go out today and I don't know if I'm wasting my time, or if it's possible to achieve something.
I've heard that the filter does cut light reflecting off the moon almost entirely, and as long as you're not that close to the moon, you'll be fine. But I imagine that there must be some other consequence, perhaps less signal to noise ratio or contrast, etc.
Does anyone have experience or has done something like that with that filter or similar? what do you think?
DanRossi avatar
You could shoot and only use the HA data to combine with data taken later at some point. The red channel in your data would be HA. Still….shoot well-away from the moon.
Mark Germani avatar
Like @DanRossi says, stay clear of the moon and maybe choose a really bright nebula. Keep exposure times on the shorter side of normal. If I remember correctly, the L-eNhance has a wider bandpass near OIII and captures H-beta too, which I imagine would let a lot more moonlight through than the L-eXtreme, which is what I use, so I second the recommendation to just use the Ha/red. But try it out and see what you get!
Jonny Bravo avatar
Take your gear outside and try. What have you got to lose? Learn what it's like imaging under a nearly full moon. See for yourself what kind of impact it has on your data. smile
Well written Engaging Supportive
Thank you both very much for the answer. And of course @Jonny Bravo , that is what I did. The best way to answer me is to try it myself. We'll see tomorrow what I get!
You can shoot even in broadband, let alone in wide-band such as the L-eNhance, with the full moon. Just choose brighter subject or you'll be wasting time. And keep at least 3 hours away for broadband and 1.5 for a filter like the L-eNhance.
Monty Chandler avatar
Absolutely!  That's what that filter excels at.
Marcellastro avatar
Do it! You can definitely blame the Moon later… if you get bad results! I use the L-extreme in full moon and in the city and I’m super happy. I guess also the L-enhance could help a lot. Especially in a dark area.
Mark Germani avatar
I briefly tried the L-eNhance, and imagedNGC 281 in 60-70% full moon with decent (I think) results. Definitely worth it, plus you can also use those full moon nights to put on a broadband filter and grab RGB stars for other projects that you might be using the L-eNhance for.
I just processed the resulting image from yesterday! Surprisingly I captured a lot more nebula than I expected. It was quite close to the moon, and therefore had less expectations. This filter amazes me more and more. Although without a doubt I did not get a clean image of noise and with good definition, besides that I had a little blur with the focus. Here is the picture: https://astrob.in/msytt9/0/. It was a good experiment and I am satisfied with the result. In the new moon I will put many hours to this nebula!
Mark Germani avatar
@Tomás Andonie nice Horsehead! I love the colour. I'm curious, though, how are you using a 2" L-eNhance filter with your DSLR & Lens?
Mark Germani:
I'm using a 58-48mm adapter to fit it to the front of the lens. It's the only method I found to use with a photographic lens. And it does not generate obvious vignetting, or at least with the flats, I do not have any. I'm still saving up to buy a refractor haha ​​I'm attaching a picture for you to see.
Mark Germani avatar
That is super cool! I bought a similar adapter to attach my L-eXtreme to my 50mm lens, but I've never had the opportunity to test it out. I'll have to give it a shot!
Well written Respectful Engaging Supportive
MikeY_Astro avatar
I've shot with a number of different DNB filters, and I'll generally shoot targets that are northern (for my location) when the moon is bright. It works, even using the LeNhance! Best way to tell is to just try it and see. Some of the more expensive DNB filters will allow you to shoot just about any part of the sky with a full moon.
which filter to choose for astrophotography
After several years of visual observation, I want to start my adventure with astrophotography. I won't replace all the equipment, what I have is Askar FRA400, ASI 533MM-P, filter wheel. There is a lack of filters for astrophotography. I don't...
Discusses filter selection for astrophotography, directly relevant to L-Enhance filter question.
Jul 21, 2024
A PSA/Rant/Warning/Opinion on CLS Filters, Light Pollution Filters, and Tri or Quad Bandpass Filters
Summary: These products are misleading in their marketing and do not return a result that is worth your money. This is intended to be a warning message that I'd copy/paste to people considering buying one of these filters, but I figured I'd p...
Addresses light pollution filters and their effectiveness, relevant to filter performance discussion.
Dec 3, 2024
