Imaging near bright stars
2 replies192 views
Corey Rueckheim avatar
I've taken a couple of images of the Horsehead Nebula, and I get a bright blue spike intruding on the image from nearby Alnitak (see this image for example: The Horsehead Nebula - B33). I see plenty of other similarly framed images that don't show this problem. What is the "secret"?
Jarrett Trezzo avatar
Not really any secret per se other than darkening the inside of the scope with flocking or baffles, etc. It is an internal reflection. Unless you are willing to do some surgery on the scope to do this, there isn't really anything you can do. I've seen worse reflections!
Supportive
xordi avatar
I had similar issue with my C8. I moved the scope between subs much more more than normal dithering does and PI rejection could remove most of it, the rest I removed with some other cosmetic tools.
Newtonian problem with spikes
Hello. If you see my last image of M101(link below) you can see spikes in the small stars. This spikes are diferent (I Think) that the typical spider spikes of all newtonians in big stars. https://www.astrobin.com/4m79f2/B/?nc=user I don't know w...
Newtonian spikes differ from bright star diffraction spikes; may explain Alnitak artifact.
May 11, 2021
Tips for dark nebulas
Hi, I'm looking to see if anyone has tips for acquisition and/or processing of dark or reflection nebulas. In particular when using LRGB. Aside from darker skies and more integration time, is it better to get more RGB frames for these style image...
Tips for dark nebula imaging directly addresses Horsehead Nebula acquisition and processing.
Oct 16, 2021
Problem with Star Halos: any advice gratefully received
Dear Astrobin friends, I wonder if someone can help me with any advice. Lately, I have been struggling with the increasing appearance of strong haloes around my stars. I am using a GSO RC8 + TS2inch corrector + ZWO 6200MM camera with 7-position filte...
Star halos and bright star artifacts similar to reported blue spike problem.
Nov 4, 2021
Diffraction starburst around bright stars - Sharpstar 15028 HNT f/2.8
Fine tuning a new acquisition, the TS Hypergraph 6 version of the Sharpstar 15028 HNT. All is good, I like it a lot, but have quite an annoying problem with starburst diffraction. The image below shows two main problems (1) The starburst itself (coul...
Diffraction spikes around bright stars directly relevant to Alnitak spike issue.
Sep 1, 2021
