Ewen avatar
I’ve just started using PixInsight and am relatively new to astrophotography in general. I processed data on M31 (https://astrob.in/yn3mn2/0/) and am looking for overall suggestions on next steps and areas to improve. I’m colourblind so I’m hoping to get some feedback on the colours in the image and the saturation levels especially.
Ewen
jewzaam avatar
Looks pretty good! Everybody's tastes are different, I personally would go a little less blue in M31 but it's a nice contrast with the core.
Unrelated to color, you appear to gave a backspacing issue. All corners radiate outwards indicating the sensor is too close to the flattener. Try adding some spacers. Remember to add 2/3 the thickness of any filter being used to your backspacing.
https://optcorp.com/blogs/deep-sky-imaging/how-to-set-the-correct-back-focus
Well Written Helpful Insightful Respectful Concise Engaging Supportive Perfect post
Ewen avatar
Thanks for the comment on M31. I did notice that I have a backspacing issue. I’m pretty new and thought I needed 55mm. In fact my set-up needs about 70mm. I have better spacing now. I’m waiting on a clear night to see if the issue has been corrected.
All the best,
Ewen
Pistachio_Enjoyer avatar
Do you have a field flattener? If so, then backspacing is your only significant issue impacting your image.
Blaine Gibby avatar
I think over all the colors are great, except the transition from the core to the outer regions, from the gold to cyan is a little abrupt. I don't know much about pix insight, but that type of issue in astro pixel processor usually comes up with color calibration and adjusting the slope to make a more natural transition usually takes care of it. I tend to also like to crush my stars a little more but you have good color in them smile
Dale Penkala avatar
Very nice image Ewen! As mentioned above defiantly have a backspacing issue but other then that the color & contrast are mainly a personal taste thing at this point. For me I think I would experiment in PI using a mask and try a slight HDR transformation just to see if I could pull a tad more detail out of the core. But again thats just me and my tastes.
Great image over all except the back spacing issue.
Dale
Respectful Concise Supportive
Ewen avatar
Thanks Dale,
I agree that the backspacing is an issue. I think I now have it solved. I’ll look into the hows and whats of HDR transformation and see if I can create a revision.
I do appreciate the feedback.
Ewen
Ewen avatar
Hey,
Yes I do have a field flattener and I think that is why I have the backspacing issue. I didn’t initially think about how it would change my backspacing away from 55mm. I connected with WO and my Flat 73 requires about 70-71mm backspacing. I’ll be playing around with that number and hope that my future images won’t have the same issue.
Thanks for taking the time to comment. Clear skies.
Ewen
Hey,
Ewen
Always handy to have a ruler around to measure precisely. Good luck and of course, clear skies.
Ewen avatar
Blaine Gibby:
Thanks for the critique! I think I might need to increase the “fuzziness” on my range mask in PixInsight to allow for a smoother transition. I’ll give that a try in my next revision.
Also, I want to make sure I understand what you mean by “crush” your stars. Do you mean that you like to reduce them?
Ewen
Blaine Gibby avatar
Yes, I like to reduce them. Typically I separate them from the DSO and then process them separately
Woodbine avatar
I think this is a pleasing image, I particularly like the nebulosity.
As you are using Pixinsight, you may like to try the free trial of BlurExterminator. to see how it performs fixing the elongated stars in the corners.
I have no affiliation with RC-astro, just a happy user.
https://www.rc-astro.com/resources/BlurXTerminator/index.php
Well Written Respectful Concise Supportive
Thomas avatar
Looks good so far and some good feedback. One thing you might try that I've found particularly helpful on M31 is the Dark Structure Enhance script. At least i think that's the name. It's in the script menu, not the processes. Will help bring out those dust lanes a little more.
[RCC] M31 first attempt
Thank you for suggestions for improvement on my first deep sky image. Image M31
Author seeking M31 processing feedback; directly relevant to source post topic.
Jan 21, 2021
[RCC] IC5146 combining OSC broadband and dual narrowband
After being into astrophtography for almost 3 years now and using pixinsight for a year, I am definitely enjoying the improvements ive seen since even earlier this year when I felt confident in getting my images rated. Anyways my latest image is one ...
PixInsight processing experience; offers comparative perspective on improvement over time.
Sep 12, 2024
[RCC] OSC to Hubble Processing Critique
Hi everyone, I’m looking to improve my OSC processing and would love some feedback on how to get better results. Specifically, I’m wondering if it’s possible to achieve smoother color blending, like with a mono camera, instead of the mottled effect I...
OSC processing feedback directly relevant; author seeking color/saturation critique expertise.
Aug 31, 2024
[RCC] I need help to improve my technique and keep learning
Hi everyone! My latest image is M101: https://www.astrobin.com/na7n09/ I am quite satisfied with the final result, but this is why I need to know what else is needed to create an even better image. Therefore, I would appreciate it if you could help m...
Requests technique improvement feedback; similar learning stage and goals as author.
May 21, 2024
