Is there such thing as a tri band filter like the L-Enhance that only allows Ha, OIII, and SII? I don't even know if that's possible but figured I'd ask.
@Monty Chandler it seems like these narrowband filters are better suited for mono cameras, to take advantage of the split channels. I've been seeing images taken with triad and other expensive filters with OSC and they look the same as the L-Enhance, so I'll just stick to that.
Btw, Hb is in the blue-green part of the spectrum.
@Jonny Bravo I wonder how much extra structure will be visible using the Radian Ultra compared to the L-Enhance. In Photoshop curves, when I use the per-channel contrast enhance, it brings out the different colors very well, but it fries the image. If I can find out how to get that effect without cooking the image that would be cool. Right now I take my stacked DSS raw into PS, copy/paste each channel's data into a new image (same dimensions and bit depth) then work from there. I find I get more color control and dynamic range with this method as opposed to just working with the stacked raw directly.
Jonny Bravo:
There is no way to separate the S2 from the Ha or the Hb from the O3 when using the Radian Triad Ultra with OSC camera. The S2/Ha will both map to the red pixels and the O3/Hb will both map to the green/blue pixels. You can use various pixel math expressions along with masking and curves techniques to create an image that has the same kind of coloring you'd see in a true SHO image created with a mono sensor and dedicated filters.
Given the above, you might be asking why the quad band filter even exists. The added bandpasses will give some more structure (well, at least the S2 will). The Hb doesn't give any different structure than the Ha data. However, the light _will_ have an impact. You'll get some more purple in the hydrogen areas (because Ha is red and Hb is blue).
While expensive, I think the Radian Ultra does provide some additional structure/light to data you capture with OSC sensors. Whether that's worth the cost of the filter is up to you to decide
Dale Penkala:
I must be missing something here in that I use dual narrow band filters with my OSC, but when I process the data in APP I’m able to extract the Oiii & Ha channels. Then for the SII I create a synthetic channel and then combine the channels for the respective color pallet. I have many images on my profile that I’ve done this to. So I don't understand the comment that this can’t be done with a OSC camera.
If I was to do shoot my data with say the quad and or triad filters I’d just do the same thing in APP, so I don’t understand why others are saying you can not do this. For me however I’m happy with just the DNB filters that I use so the extra $ that these Tri & Quad band filters cost isn’t worth it to me.
Sorry if I’m missing something here.
However, there is the IDAS NB3 filter, which is a duoband filter that passes SII only in the red, and OIII in the blue-green. So if you use the L-eXtreme to do Ha/OIII then you can do another set of exposures with the NB3 as SII/OIII. It does double up on the OIII, but that is not necessarily a bad thing since OIII in many targets is not that strong.
Jonny Bravo:Dale Penkala:
What can't be done with the tri-/quad-band filters is the separation of signals. There is absolutely no way to say "this red pixel is S2 and that red pixel is Ha" or "this blue pixel is O3 and that blue pixel is Hb". With a dual-band filter you get Ha and O3 light. Those you _can_ separate pretty effectively as the Ha will map to the red pixels and the O3 will map to the green/blue pixels. I wrote "pretty effectively" because most OSC sensors have some amount of bleed (i.e. green picking up red light wavelengths). For example, take a look at the graph for the 2600MC and you'll see about 15% green and 5% blue response at the Ha wavelength.
So, let's say you have a filter like the Radian Ultra and it gives you S2, Ha, O3 and Hb. There is no way at all for you to say "I'm putting S2 into R, Ha into G and O3 into B". It cannot be done. You have to do what you're doing: create some kind of synthetic channel based on whatever combination you like.
Dale Penkala:
If I wanted to truly get a SII channel then I would purchase an SII filter and shoot it in mono mode for the SII channel and be done. Grant it, it wouldn’t be as efficient as a true mono camera but I’ve heard/read of others doing this. (Can’t remember where I read this) I’ve never done it and have thought about giving it a try just to see how what the results would be. I’ve been happy enough with what I’ve gotten so really never decided to spend the money on the SII filter to give it a go.
So to compliment my L-Enhance filter should I get a straight SII filter and map that data to my green channel? Should produce interesting results.
Rick Veregin:
