Why do I get this ring around my photos?
9 replies447 views
Piers Palmer avatar
I shot the Pleiades last night (47x180" in the end) and have added 20 x flats, 20 x dark flats, 20 x bias and 20x darks. I've stacked in Deep Sky Stacker and processed in Pixinsight, using ABE, Photometric Colour Calibration and SNCR.
It comes out of Pixinsight looking like this.
There's a glow around the edge (you've probably spotted it!). I've tried a few things like DBE but it doesn't seem to make any difference, and it's there on a lot of my shots. I can reduce it in Photoshop, but never eliminate it. Any ideas why is it there in the first place? I'm guessing I'm processing badly and probably don't need bias and dark flats, or dark flats...or either? Maybe it's something else? Maybe the sky really does look like that?!
Any advice, gratefully received!
Michael Timm avatar
In my experience this is an artifact of ABE. Don't use it, try DBE instead.
Bad flat-fielding probably and you really shuldn't use DDS when PI is available. Do that again in PI and send us a preview without any processing. Probably ABE is the culprit for the inexperienced but we shall see.
Piers Palmer avatar
Oh....yeah....that's better!
That was easy.....thank you very much! I always thought the two went hand in hand. Duh.
Piers Palmer avatar
***I've got a lacerta flat field panel which I can adjust the brightness of so I think I'm going to be ok there (if that's what you were meaning), but I'll take a look at stacking in Pixinsight later this morning.
Thanks
Almos Balasi avatar
I agree with Michael, it can be an artifact of ABE. Very important to check if the same glow appear or not on the original raw images. If yes, than it is because of the very fine dew on the lens.
Piers Palmer avatar
Thanks - no dew on the lens and this is a single frame, so yes, appears to be something to do with ABE.
I'm reading a tutorial on stacking in Pixinsight. Good gracious!
Stuart Taylor avatar
I think ABE can produce decent results provided you set the function degree parameter judiciously. For straightforward situations (say a galaxy in the centre of the field and a simple gradient) set it to 1. For more complex situations (such as several areas of nebulosity and unsymmetrical gradients) you can increase to 2, 3, 4 etc. It's worth experimenting (although you might as well then have just placed your samples yourself in DBE!).
Explained here (and also using M45 as it happens) https://youtu.be/UKd0pUBSZ6o?t=606
Well Written Helpful Concise
Piers Palmer avatar
Brilliant - thank you!!
deleted avatar
To anyone coming across this with the same issue using DSS and Photoshop, Astroflat Pro can fix it 👍
Any idea what's caused this?
I shot M74 last night and having processed the frames, have something that looks like amp glow. I know it can't be; my camera is an ASI2600MC Pro, but I can't work out what it is. It was taken through a Vixen SD115, so I can't imagine the...
Edge glow issue similar to yours; discusses potential causes and solutions.
Sep 12, 2024
RFA PixInsight Stacking Problem, Calibration Problem, or... who knows what problem
Issue: I receive the failure below when running WBPP. Results in what seems to be vignetting. The below image has had Graxpert, ABE, SPCC and stretched. Saved as jpg. I don't detect vignetting in the subs. Maybe my calibration frames are the prob...
Vignetting and calibration problems in PixInsight processing pipeline relevant to your workflow.
Aug 2, 2024
