Find the good backfocus with my 200/800 SkyWatcher
5 replies415 views
Valentin JUNGBLUTH avatar
Hello guys,
I have a Newtonian SkyWatcher 200 Quattro P (200/800) with the SkyWatcher Coma Corrector GPU 4-lenses and ZWO ASI 1600 MMC Pro.
Filters are ZWO LRGB SHO 31mm with 1.9mm of thickness.
However, I'm getting some troubles in order to find the best backfocus with my setup.
I read at different places that the good backfocus with this coma corrector model is : 53.66mm with 800 mm of focal lenght + 1/3 of filter's thickness.
First question :
Among astrophotographers on this forum, some people have the same configuration ? If the answer is yes, could you tell me the exact backfocus you have on your setup ?
Theoritical backfocus for 800 mm focal lenght :
53.66mm (BF for 800mm) + 0.63mm (1/3 thickness of filter) = 54.293 mm
Is it true up to now with my calculation ?
Second question : my optical train with 54.30mm
Ring 14mm (9mm + 5mm) + (spacer 0.8mm) + Ring 11mm + Ring M48/M42 2mm + Filters wheel 20mm + ZWO ASI 6.5mm
Do you think there is a better coma corrector with higher tolerance than mine ?
Thank you very much
I have a similar, but not identical, setup: SPX 300 f/4 with same CC and ASI 294MC (same backspace) with a filter holder with filter around 2mm thick. My back focus spacing is 55.6 mm +/- 0.1 mm and I can't find it being an issue. TS-GPU and SW GPU (or SharpStar) are basically identical optically and at that price point hard to beat. Honestly, I can't see variations in back focus of the order of 0.5mm causing any issue as far as optical performance is concerned. In fact, I've tested it to death and still can't tell whether there is any difference at all (just remove a filter and you'll see).
Earle Waghorne avatar
Hi Valentin,
I have the same system, a Quattro 8cf which I use with a ZWO 1600 or 294. The Skywatcher f4 coma corrector is quoted at 55 mm backfocus and I've found that this works. It is usual to add the 1/3 times the filter thickness.
Rather than stressing about the exact distance, I would suggest getting it close, say go for 56 mm and try it out. If the stars at the edge are long and aligned towards the center you need to increase the distance and if they are long but aligned around the image you need to shorten it. In fact this system is fairly forgiving, you probably can't see changes at .5 mm. I also have an old GSO corrector, with a 75 mm backfocus and this quotes a tolerance of +- 5 mm.
Hope this helps,
CS, Earle
Helpful Concise Supportive
Leonardo Landi avatar
Same setup too and found that 55 mm works pretty well. In my opinion on that scope collimation matters much more than backfocus… and it's quite a mess. Idiot question: are you sure that your problems are caused by BF error?
Thank you very much @andrea tasselli with your answer. So in your calculation, you took the 55mm backfocus and you added the filter thickness in order to get 55.66mm ? I have to try this to see what happen exactly with the same backfocus.
Unfortunately, they are too much clouds since 3 months on my site.
Earle Waghorne:
Hi Valentin,
Hope this helps,
CS, Earle
Hi @Earle Waghorne, thank you very much to take time in order to answer me. I can read at different places 55mm is given for 1000mm focal lenght. So you have about 55.5 / 55.6 mm by adding filter thickness in your configuration ?
I have to do some tries in order to see the impact with 55.5 / 56mm of BF.
Thank you anyway !
Leonardo Landi:
Same setup too and found that 55 mm works pretty well. In my opinion on that scope collimation matters much more than backfocus... and it's quite a mess. Idiot question: are you sure that your problems are caused by BF error?
Hi @Leonardo Landi, you have 55mm + about 0.6mm added due to filter thickness ? I would like to be sure that my BF is good before to look if I get tilt or something else.
To get return from other people which have the same setup is important in order to compare.
ManuManu avatar
Hello Valentin,
I have a Newtonian 800/200 with the same GPU and IMX571C sensor. With this configuration (APC-C format) the coma correction is OK but there is no margin.
After several hours my experimental backfocus value is 54mm ….. So your calculation is right but perhaps add a 0.5mm spacer in your setup. Better should be adding a M48 ring of 26mm to avoid cascade of rings and tilting!
Emmanuel
Backfocus RCC1 Newton 200/800 : test result
Hello, Here is a post based on my own experience (RCC1 - UNC 200/800 FD4), can be helpfull for those who are using the same "setup" (or near) - standard RCC1 backfocus (BF) is 91,5 mm (connected on M42 corrector/ 94,5 mm -mechanical lenght-...
Directly relevant - discusses backfocus adjustment for 200/800 Newtonian with coma corrector setup.
Aug 8, 2021
Question about optics : Barlow and extension tubes
Hi All, I hope some people having good knowledge in optics will help me : I have bought a 4x Powermate and need to use some extension tubes to be able to focus. On my setup I have connected the Barlow directly to refractor, and then the filter wheel ...
Covers back focus issues with coma corrector and camera setup.
Jan 30, 2021
Star Analyzer 100 or 200?
Hello: I have some questions about wich star analyzer prism should i use. This is my equipment: - QHY 294C Pro - GSO Newton 200/800 F4 - ZWO Filter Drawer - Sharpstar MPCC Coma Corrector 1x - ZWO Off Axis Guider Could you please indicate wich star an...
Similar Newtonian telescope setup with ZWO filters; backfocus and equipment configuration relevant.
Jul 5, 2024
