Adapters to connect ASI2600 to Epsilon 130ED
4 replies146 views
Raúl López avatar
Hi!.
I am thinking of buying this telescope. What adapters do you need to attach the ZWO ASI 2600 camera to the telescope?
Is it easy to collimate the telescope and does it hold collimation well?
Thank you.
David Nozadze avatar
Hi Raul!
I have an Esilon 160 ED. It came perfecly collimated from the vendor and stayd collimated for almost two years. When I checked it last time, it was off by just a tiny bit. Collimation is not simple, as it is a very fast scope, but not impossible. You just need to be very accurate and patient and do tiny adjustments.
If you are bying a monochrome verison of ASI2600, then you will attach it to a filter wheel with screws direcly on the camera's faceplate. Then the filter wheel can be attached to the Epsilon's focuser with M42 female to M54 female adapter, which should come with your camera, or M42 male to M54 female adapter. You can buy those very cheaply on Amazon etc.
If you your camera is a color variant, then you will not need a filter wheel obviously and you attach the camera to the focuser directly with the same adapters. You will only need to make sure that the backfocus distance is achieved with necessary number of extenders in both cases. For E160 it's 56.2 millimeters. Not sure about the E130, but I am think it will be indicated in the manual.
But to sum up, Epsilons are among the best astrographs the money can buy. Definitely go for it. You will not regret it!
Clea skies!
D
Raúl López avatar
Hi!. Thanks a lot.
You had a tilt problem?.
I am undecided between RAsa 8 and Epsilon
Raúl López:
Hi!. Thanks a lot.
No tilt problem. One of the many strenths of the Epsilons are the focusers. They are very precise and wobble-free.
As for your choice between RASA and E130, 8" apperture is always bettern than 5". You really need to copare RASA8 and Epsilon 180.
If you are going to use a color camera mainly, then RASA is hard to beat.
D
Raúl López avatar
David Nozadze:
Raúl López:
Hi!. Thanks a lot.
D
Thanks a lot David.
Adapters to attach a Sony A7R3 camera to a telescope?
Anyone have this same camera and has it attached to a telescope?
ASI2600 camera attachment to telescope with adapter recommendations.
Dec 7, 2020
Backfocus on T2 to Canon EF adapter - backfocus or other problem?
Hi there, during the last two weeks I put together a mobile rig to work with some students from my wifes school. This setup should be used to explain the basic steps of doing astro photography and hopefully attract some young people for the beauty of...
Discusses T2 adapter backfocus issues relevant to camera attachment setup.
Aug 13, 2024
ASI 2600 MC owners - I need your help
Dear 2600mc users, I'm thinking of buying this camera, Yet there is one thing that concerns me - I wanna do both DSO and planetary So Im wondering what the FPS is like on 2600 Could someone plz test it? Here are the settings; (you'd probably ...
ASI 2600 camera owners sharing experiences and setup advice.
Jun 2, 2024
Equipment needed for exoplanet discovery.
What equipment is needed? #newlifegoal
Directly addresses equipment compatibility for specific telescope and camera setup.
Apr 24, 2021
Samyang 135 backfocus calculating problems with zwo 2600+efw
Hi i have this lovely lens from 1 year ago. Till now i used whit my last 294mcpro but now i have zwo 2600mcpro+2600mmpro attached to efw filter wheel. The backfocus for this lens is 44mm (canon mount) so i removed the 2600 tilter+efw+m48 adapter (10m...
ZWO 2600 camera attachment and backfocus calculation with equipment.
Nov 18, 2024
