It depends on what you are trying to achieve.
If the intent is to accentuate the Ha in a wideband image of, say, a galaxy, then this can be achieved by adding a percentage of the narrowband Ha to the R channel of the RGB image using Pixelmath or similar, or by blending into the R channel in Photoshop.
If the intention is to produce an image that has both strong narrowband targets and wideband targets in the same frame (e.g.
Dengel Hartl 5 and friends) then the two stacks can be combined in PixelMath using a Max formula or similar as appropriate to the situation. This could also be done in Photoshop, blending and masking the relevant areas.
This works better if the stars are removed first.
There are also PixInsight processes such as NBRGB Combination, but I've never managed to achieve quite what I wanted with this.
Some useful tutorials: PixelMath method:
https://www.youtube.com/watch?v=1Wd7VxpMCH4 NBRGBCombination:
https://chaoticnebula.com/pixinsight-nbrgb-combination/ Continuum:
https://pixinsight.com/tutorials/narrowband/index.html
e.g. Narrowband (OSC using dual narrowband filter)
RGB using L_Pro:
Max( narrowband, RGB)
