Uranus C / ZWO 585MC for DSOs
11 replies1.1k views
Worth the upgrade ?
Multiple choice poll 39 votes
49% (19 votes)
15% (6 votes)
36% (14 votes)
Luka Poropat avatar
Is it worth getting a Uranus C / ZWO 585MC for deep sky imaging , mainly long exposures 1-5min … to upgrade from a good stock dslr (no intentions of modding it) , instead of spending 3x the amount and getting something like a ZWO 533MC Pro ?
Will the new BSI sensor be sufficient enough with its low read noise to get good images , or is the cooling and a bigger sensor worth the 3x cost (at least here where the VAT is 25% ouch).
[deleted]
Unless you're under really dark skies, you may not need exposures longer than 30s in most cases. Could help beat the seeing at longer focal lengths, especially when going after planetary nebula and galaxies.
Also helps in familiarizing yourself with the imaging routine if you're not able to do so with your DSLR. In my case I was using a Fuji X-T100 with no computer controlled option. I set up an off axis imaging config using my Player One Neptune-C II and ZWO ASI290MM mini. Results were promising.
One benefit of these smaller cameras that I don't see mentioned often is that they're light weight. Chances of tilt due to sag are minimal.
I had fun using my Neptune-C II for DSO. I mostly use it for planetary now, but have considered using it to get detail shots of DSO and combining with wider field data.
Vlad Sazhen avatar
I've got one. So far had only one test with it, but was very pleased. This is just 80mins in the white zone (Bortle 8) with ZWO Duo-Band and Canon 300mm F/4
P. S. Disregard the wonky stars, this is a lens problem
Jesco avatar
Have you considered getting a ASI533MC (not Pro), i.e. the uncooled model?
Looking at the specs, the ASI533 has the same dark-current at 10C that a ASI1600 has at -10C. Coupled with the fact that it's amp-glow free that makes it very attractive for DSO.
I would never invest in an astro-specific camera with the intention of doing long exposure DSO imaging that isn't cooled.
You dont need to cool much to get tremendous noise benefits, not to mention consistent and accurate calibration files.  The difference between a cooled and non-cooled astrocam is not subtle.
If I was to use a non-cooled astrocam, it would just be a dslr.
Helpful Insightful Concise
Jesco avatar
Chris White:
No offense, but have you actually compared datasheets for the IMX533 based sensors? Even uncooled the noise characteristics are superior to a cooled ASI1600 at 20K below ambient. Your point about the calibration files is a valid one, but much less critical considering how well-behaved the recent sensors are.
In the end it boils down to what the OP wants. Even a modern uncooled camera will be a big improvement compared to his older DSLR. TEC cooling is a significant price adder and you have the added complexity of more power supplies and possible sensor frosting. For casual imaging he might be totally fine.
For high-performance imaging, sure. No way an uncooled camera would be good for this. But not everybody has the same set of intentions
Jesco:
No offense taken.  The OP asked for opinions and I provided mine.  What he, or you or anyone does with this contribution it up to the person deciding.  I'm not here to debate or change anyone's mind.  Just provide my input.  My opinion remains unchanged.
Luka Poropat avatar
Jesco:
Chris White:
*** BTW my dslr is 2022 new a 250D so 2018 sensor with 3-2electrons of read noise, and this is for my lets call it ultra fast portable rig (SWSA + 200mm f2,8 )  , im using a G4 - 9000 (cooling to -20) as my main shooter but found that new CMOS are just better optimised (less noise per temp) so you can get away with non cooled last model sensors , im mainly considering this because i found that im shooting mainly widefield nebulae which are heavily Ha and my good dslr is stock (again no plan to mod it ), thats why im considering something like a Uranus C , the 533 is a great option but i think its still too expensive for an uncooled camera (at least here), and im a semi heavy user given that im basically travelling to shoot unless im doing it in the summer where i live basically at the observatory ***
[deleted]
I stumbled onto this video a while back. He does a shootout between an Esprit 120 w/ ASI183MM Pro and a RASA 8 w/ Uranus-C. Results were surprisingly similar.
Think it's well worth checking out his channel. That video seems to be the first part in a 3-part series that compares the data. He's made a few videos where he puts the Uranus-C to the test.
Kenneth von Berg avatar
Buy the ASI585MC... go to Rouzastro and buy a 12volt cooling kit for 70 USD.  Then you have the Starvis2 NIR advantage at a much lower cost.  Point 2, we all wait to see what does next generation tech given and how is price / performance.  While you use the 585, in 1-2 seasons from now, you'll see +26MP sensors with Starvis2 or better, and then you should upgrade to a cooled.
Andreas Zeinert avatar
Player One has a cooled version of this 585 sensor, Uranus-C pro. I would go for this if you are aiming at DSO. Ela,  https://www.astrobin.com/users/LittleGhost/ , is doing excellent images with the uncooled ZWO version, but imaging on DSO is much easier with a cooled camera, unless you are imaging under Bortle 5 or higher skies where subs exposure time is limited. Thermal noise is also present at short exposure times, which defavors faint signals. If your signal is always below the noise level on a single sub, it will never come out. Be aware that sensors heat up, when the night is about 20°C your sensor might be at 35°C and this generates much more thermal noise than the read noise. Moreover, darks are difficult to handle with uncooled cameras, since you never have the right temperature.
Helpful Insightful
Ryan Faulkner avatar
I started with the ZWO 585 and it can capture DSO, but you will fight the noise. However, it’s a good “starter” camera that you can use until the next upgrade (which was the ZWO 533MC in my case).
M 45 with the 585:
M33 with the 585
M33 with the 533 (not a direct comparison because I added Ha):
An optimal imaging sensor for astrophotography? Thinking about what might make AP better and easier...
Hello ABin! Absent the ability to image still (weather and clouds, or just poor timing on nights it does get clear), I've been pondering something: What would the optimal astrophotography image sensor look like? Thus far, astrophotography cameras...
Discusses optimal imaging sensors for astrophotography, directly relevant to camera selection.
May 9, 2024
Full rig recommendations for beginners
So I put together this list of my personal recommendations for some beginner astrophotography rigs. It was an idea for a youtube video that I uploaded and I thought I share them here and see the community's feedback! One of the most frustrating t...
Beginner astrophotography rig recommendations may include camera options and upgrade guidance.
Aug 27, 2024
