Beginner looking for a little advice
10 replies539 views
Kluson avatar
Hi Guys
I am just starting to get into this. I have a star adventurer 2i and a Canon DSLR ( astro Modified). I am now taking the first plug into a telescope for these two. I am thinking maybe the Williams Optics ZS61ii or perhaps the Rother valley Horizon 60ED.  I'm looking to start on the usual suspects - Andromeda, Orion Nebula etc. Am I looking at the right solution for this. My thoughts were that the WO ZS 61 would allow me to grow, until the bug bites deep enough for a new mount etc. But I believe that the WOZS61 and the Star tracker with the DSLR would be a good place to start my education.
Any advice would be really welcomed
Thanks
Dave
David Nozadze avatar
Hi Dave,
Those are very nice telescopes and will definitely give you excellent images. But I think your tracker might not have sufficient load payload capacity for them. I think you should consider upgrading to a bigger equatorial mount at the same time.
D
Well written Concise
kuechlew avatar
Agreed, that's a good focal length to start with and it will provide you access to a lot of nice targets.  RedCat 51 is a bit shorter in focal length and would be a good choice too.
Clear skies
Wolfgang
Well written Respectful
Reg Pratt avatar
William optics makes excellent telescopes. I've owned 5 including my first scope which was a z73.  If you do go that route just make sure you get a compatible field flattener as well. I'd go this route and stick with the tracker until you're sure you're all in on the hobby and then invest in a good mount.
Daniel DeSclafani avatar
So, I do have to agree with the common recommendation to upgrade your mount first. You should be buying the best mount you can.
However, I think at this time its not necessarily needed. What lenses do you currently own? The star adventurer should be able to handle that DSLR and a lens. Use what you have(if you have a lens). This isn't the preaching comment to "use what you own and get better". Sure it could apply, but in all honesty a lens and dslr can capture spectacular images. Look around some, and you'll see you can get results just as good, and if not, better than someone with a telescope. Don't get too hung up on the scope. I think your preferences will change as you start imaging more. This should give you time to save up for that better mount and also figure out in particular which scope you want.
Also, I own a William Optics and I am a fan of it. Good choice, although it is a bit higher priced compared to others in the same range. I do like they have dedicated flatteners with rotators on them. It is extremely helpful for framing.
Some examples of DSLR + Lens (Note this is an old Cannon 1000D 10.1mp)
https://www.astrobin.com/254501/B/?q=%22Canon%20EOS%201000D%20/%20Rebel%20XS%20/%20Kiss%20F%20%28modified%29%22&_ga=2.245328517.1226184824.1664903161-157388661.1650591235
https://www.astrobin.com/293595/D/?q=%22Canon%20EOS%201000D%20/%20Rebel%20XS%20/%20Kiss%20F%20%28modified%29%22&camera=
https://www.astrobin.com/293232/?q=%22Canon%20EOS%201000D%20/%20Rebel%20XS%20/%20Kiss%20F%20%28modified%29%22&camera=
Other canon cameras:
https://www.astrobin.com/299946/?q=%22Canon%20EOS%20600D%20/%20Rebel%20T3i%20/%20Kiss%20X5%20%28modified%29%22&camera=
https://www.astrobin.com/ymwvgy/?q=%22Canon%20EOS%20600D%20/%20Rebel%20T3i%20/%20Kiss%20X5%20%28modified%29%22&camera=
And one of the first images I ever took. Astro Modified Canon Rebel T3i with 70 - 200mm lens
https://www.astrobin.com/rgrk0d/
Kluson avatar
Hi
Thanks so much for the useful comments and advice
cheers
D
Sean Mc avatar
Well I’m going to go against the grain as I have not had a good experience with william optics smile
My advice would be to get an asiair to go with what you currently have.
Amos B. avatar
David Nozadze:
Hi Dave,
D
Can't recommend this enough. I wish I would have started off with a slightly heavier eq mount myself early on. The light star adventurer is good for something quick and light, but I'd argue there are probably better options (albeit, more expensive.)
A solid mount was the make/break for me. I was about ready to throw in the towel when fighting polar alignment through, breaking my back or knees and just generally a nuissance to deal with at times. As for scopes, there's a ton of solid options. I don't regret my Svbony scope, nor my WO Redcat 51.
Engaging Supportive
Kluson avatar
Hi Amos
Thanks very much
Yes I thought long and hard and indeed  did upgrade the mount. I took the plunge to an AM% and love is with the ASIAIR.  The Star tracker is now used for DSLR stuff. We are having so much fun
Thanks
Dave
Sean Mc avatar
Hi Amos
Thanks very much
An am3/5 and an asiair is a big investment to make. I did the same earlier this year. Best investments I’ve made in astrophotography.
Hi from Germany
Hi, I am a beginner in astrophotography since a while now. A couple of years ago, I started with a Star Adventurer 2i and a DSLR and quickly got fed up with it. Fiddling around with a wobbly photo tripod, guessing where to find polaris in a light pol...
Author shares similar beginner setup with Star Adventurer 2i and DSLR camera.
Jun 23, 2024
Hello from Chicago
Just recently bought my first telescope (celestron 6se. While I know there is no perfect scope for both visual and astrophotography I figured it may be a decent middle ground. I am new to all of this and that is why I chose a goto scope. Being in the...
Beginner with equipment setup questions for astrophotography pursuits.
Mar 28, 2021
[RCC] my first two images!
Hi everyone. I am just starting out on astrophotography, having been a visual observer for many years. I uploaded my first two attempts yesterday and would be grateful for your feedback. Both were shot with my 20cm f/10 SCT and a 0.63 focal reducer m...
Beginner astrophotography advice with DSLR; similar experience level and equipment type.
Jun 1, 2021
