First Time Processing SHO with APP (M31) Help Please!
17 replies361 views
schmaks avatar
I have roughly 34 hours of integration time on M31, but when I get to the point of "combine RGB" in APP, things are turning out very green and I am stuck not knowing how best to proceed.
I think I have some decent data here but need a little help over the finish line. Can anyone shed some light on something I may have missed or should do from here? I think the detail I've captured is good but the coloring is headed in the wrong direction.
Here is a link to the .fits files for each channel if anyone wants to play with them / show me what's possible with this data. Below are the images out of APP (low res previews) for reference.
Thanks in advance!
Combined RGB:
Here is S:
Here is H:
Here is O:
Andy Wray avatar
My question would be: why are you trying to image M31 in SHO?  I would image it in RGB and maybe enhance it with some Ha data.  I did try to use your SHO data, but it was very lacklustre compared to an RGB version.
FWIW:  this is your JPEG image above with a 95% SCNR green reduction in Pixinsight and an automatic background extraction:
Well written Insightful Concise
Scotty Bishop avatar
Sounds like you probably meant to do it in HSO, not SHO. A standard HSO will map Sii to red, Ha to green (very apparent in your image), and Oiii to blue.
In APP when I want to do the Hubble Palette in SHO I do the sliders to where I have Ha with 50% red, 100% green, 15% blue, and 50% luminance, Oiii at a multiplier of 4.000 with red at 15%, green at 90%, and blue at 100%, then Sii at a multiplier of 2.500 with red at 100%, green at 40%, and blue at 15%. I will vary the low number on each color by 5% either way to get what I want, vary the luminance on the Ha channel from 25% to 75%, the multiplier on Oiii from 3.750 to 4.500, and vary the multiplier on the Sii channel from 2.500 to 2.750.
Getting back to your image of M31, why not do LRGB and then Ha? Run the Ha at 100% and a 2.000 multiplier, L at 50%, then RGB all at 100% with LRGB all at a 1.000 multiplier.
schmaks avatar
Andy Wray:
Thanks for trying. My camera is mono with SHO narrowband filters. So at this point I’m shooting SHO.
Andy Wray avatar
Andy Wray:
I also use a mono camera, however I have 7 filters:  Lum, Red, Green, Blue, Ha, Oiii and Sii.  This is a fairly usual setup.  For galaxies it is mainly LRGB with some Ha data and for nebulas it would be Ha, Oiii and Sii for the nebulas with RGB for the stars.  Any reason why you are limiting yourself to SHO?
Well written Helpful Engaging
schmaks avatar
Andy Wray:
Andy Wray:
Still learning. This is all new to me and my first light with narrowband was this week.
I have 5 slots in my filter wheel and some information to research.
Andy Wray avatar
You've got some really nice sharp images there so your equipment is working well (probably better than mine to be honest).
With a 5 slot filter wheel (which I started with), I would use LRGB and Ha filters for most galaxies.  If you want to get into nebulas then you will probably then want to use Oiii and Sii.  I ended up swapping my 5-slot for an 8-slot filter wheel so that I didn't have to keep swapping filters.
I hope that makes sense.
If you really want to try out the narrowband stuff, I would suggest going for a bright nebula and using SHO filters on that.  I did a quick one on the Wizard nebula which is high in the sky recently as follows:
Fiddling with my scope and captured the Wizard (Added a splash of colour)
kuechlew avatar
Fully agree with Andy, M31 is mainly a broadband target with H alpha as optional recommended enhancement .
Scotty Bishop:
I believe there is a misconception. HSO means assign H to red, S to green, O to blue (i.e. HSO in same order of letters as RGB). Accordingly SHO means R=S, G=H, B=O and HOO means R=H, G=O, B=O.
Clear skies
Wolfgang
Here's a quick blast through APP and a slight tweak in Photoshop without much effort.
schmaks avatar
It sounds like I may need to focus on nebulas until I can rethink my filter setup for galaxies.
Well written
Scotty Bishop:
Clear skies
Wolfgang
Oops, I know what I meant to say and it was what you said. Substitute the HSO in my "A standard HSO will map...." with SHO. I should not type if I am looking at other things because I will type what I am looking at not what I mean.
schmaks avatar
Scotty Bishop:
I do like this direction. I am going to play with things and see if I can't salvage 5 nights of shooting and then move onward with lessons learned. Thanks!
Scotty Bishop:
I did it in APP with H as 100% R, 15% L, and a 1.500 multiplier, Oiii as 100% B, 20% G, and 5% L, then Sii as 100% G, 20% B, and 5% L. then did a batch crop, then a remove light pollution to even the background some, then a star color calibration, then selective color and increased red, yellow, cyan, and blue saturation by 30% each, pulled back green and magenta saturation by 50%, then saved as a 16 bit tiff at the default 15% stretch. I took that into Photoshop and did camera raw increasing the darks, clarity, messing with the color balance, and then pumped the saturation and vibrance, then did a noise reduction, then a deep blue photo filter, then set the histogram spikes even on R, G, and B, then ran HLVG on weak.
Been a while since I did a super quick process like that. You should be able to duplicate this.
One piece of advice though, check your focus because your stars were big. Also make sure you aren't dewing up because that will do that too.
kuechlew avatar
When imaging galaxies you are imaging stars (plenty of them ...). Stars are emitting light in the full spectrum (with some absorption lines). Therefore you want to use R, G, B and L for these targets. Wether it's worth to use H alpha in addition depends on the galaxy. Since galaxies are far apart it's usually not worth to use Sulfur or Oxygen filters. In contrast to hydrogen these elements are rare and when you are imaging a galaxy you usually only capture the red and blue parts of the spectrum of the stars in the galaxy with these filters.
Clear skies
Wolfgang
schmaks avatar
Clear skies
Wolfgang
Makes sense. May need to get a 7-filter wheel.
schmaks avatar
Andy Wray:
Andy Wray:
Definitely need to get into LRGB. With the 183GT I only have 5 slots so I’m not looking forward to frequently swapping SHO for LRGB.
This may be a silly question, but can I stack filter wheels?
Well written Engaging
kuechlew avatar
Andy Wray:
Andy Wray:
This depends mainly on two things:
a) Does your software support two filter wheels?
b) Is there enough space in your imaging train to still keep the proper backfocus distance with two filter wheels?
The third question whether it is possible to couple the ASI183GT to another filter wheel should be solvable somehow, although the approaches may be restricted by question b).
Looking at your images I saw that you used your Canon 6d for imaging. So why not use it for your RGB images? You could enhance the images with the luminance channel from your mono camera. If you register your 6d images to the luminance images of the 183GT the stacking software should take care about the different crop factors.
Just an idea. Depending on your budget buying an OSC astrocam for RGB could be another approach.
Clear skies
Wolfgang
schmaks avatar
Andy Wray:
Andy Wray:
Clear skies
Wolfgang
Thanks. My 60D is out of commission now.
I’ll be looking into options.
Rescue mission: stacking of NGC 5128
I'm at my wits' end and would like to ask for some help to save the data from a session imaging NGC 5128 that I thought would be an absolutely stunning image. I'm new to big telescopes, stacking and post-processing. I have Celestron 9.25 ...
Green color cast in M31 RGB processing similar to NGC 5128 stacking challenges.
May 11, 2024
1st Mono Imaging Session Help Please
New to mono and hoping for some insight. Just got my 2600mm paired with Antlia 2.5nm filters. Weather here in NYC has not been agreeable but I was able to get about 4 hours of SII (300s) and 4 hours of Ha (300s). No OIII yet due to the moon and weath...
Mono imaging with narrowband filters involves color channel balancing issues like yours.
Aug 18, 2024
Failure to register and integrate an Oiii dataset
Hello to all AstroBinners I need your help! i have been trying to register and the integrate a set of 100 Oiii subs but WBPP fails to do it as does the stand alone processes i was wondering if anyone out there is able to achieve integration the calib...
OIII dataset registration/integration problems relate to color channel processing difficulties.
Sep 6, 2024
