CEM70 MAINBOARD PROBLEM
IOptron CEM •1 reply•91 views
Reza Mohammadi avatar
Recently i bought an ioptron cem70. for several nights i used it. but last night during working and slewing some times could not slew. so i switch it off. after 1 minute I brought it to zero position manually, then i switched on, but power button could not illuminated and the hand controller turned on and just show ioptron logo. and then after few seconds this message came up: "Connection error detected in following board(s): Main Board".
ioptron advised me to check power source, HC cable and sockets, etc. finally I should send HC and main-board to the ioptron office to checking and repairing.
It will be free of charge except S&H if the mount is under 2 year warranty.
James Sokolowski avatar
Well that's a bummer… I have a CEM 70G and sometimes the Guide camera won't connect to my NINA thingy…. so I have to open up the back of the camera, unplug the USB which requires a pair of pliers and plug it back in… but other than that, my mount has been great…
10micron mounts shutting down on their own?
Hi all, not posting in the equipment forums because I think this is more firmware related and should be the same for other mounts from 10micron. After being switched on for 5-ish days, and of course usage at night, our GM4000 HPS decided that it was ...
Mount hardware troubleshooting relevant to connection/board errors.
May 14, 2024
