Gain setting for a QHY 533C camera
5 replies227 views
Kevin Dixon avatar
Hi folks.  I just purchased my first One Shot Color (OSC) camera - A QHY 533C camera.   I am looking for guidance on what value to set for the gain for the camera.  Thank you in advance for any advice that you can offer.
Clear skies,
Kevin
Long exposures (>=300s), unity gain. Short exposures (<=180s), 60. In between, your choice, depending on the subject.
Kevin Dixon avatar
Thank you Andrea.  I am using The SkyX Professional for image acquisition and it does not have a setting of unity gain.  It has gain values that range from 0 to 170.  Which value would most closely mirror the unity gain setting for deep sky objects?
Clear skies,
Kevin
Unfortunately I don't have the SkyX so I can't tell. The best thing is to get a proper analysis of the performance using SharpCap, the result of which would tell you what gain value will be unity gain and what gain would given the drop off in readout noise (60 gain units refers to that condition). Remember that offset and gain correlate in inverse manner and for NB imaging (assuming you would use dual-band filters) you might want to push more on gain if you're after the faintest stuff.
Helpful Insightful Respectful
kuechlew avatar
Unity Gain is 68 according to the manufacturer: QHY533M & QHY533C Astronomy Cooled Camera | QHYCCD
Clear skies
Wolfgang
Kevin Dixon avatar
Thank you Wolfgang and Andrea.
Clear skies,
Kevin
"GAIN" setting on ASI585 MC PRO
Hello, I just bought a ZWO ASI 585 MC PRO camera which replaces my CANON EOS250D camera. I took my first photos yesterday evening with this camera, the sky was pretty good, the Moon not yet up… I set the GAIN to 252, as recommended by the ZWO i...
GAIN setting guidance for one-shot color camera similar to yours.
Aug 23, 2024
Ideal telescopes for ZWO ASI 183MM
Howdy folks, I recently purchased a ZWO 183MM Pro camera with the built -in filter wheel (183GT). Last night was first light utilizing the camera with a 6-inch Newtonian which has a focal length of 518mm and a focal ratio of 3.45. Images from this co...
GAIN and camera settings for recently purchased ZWO one-shot color.
Aug 12, 2024
Free osc data set
Hi there, due to the amazing weather I'd like some decent data to practice my l33t processing skills on ;) but I'm struggling to find any osc stuff. Even osc + narrowband would do if I can just not use the narrowband data? Any suggestions or ...
One-shot color data and processing relevant to OSC camera use.
Jun 9, 2024
