UV/IR Block at F2
5 replies158 views
Steve Spring avatar
I shoot with an ASI533mc and have always used a UV/IR cut filter when taking RGB images to help with star bloat.
Does anyone out there use a UV/IR cut filter along with a Hyperstar or RASA and if so could anyone please recommend a suitable filter?
Regards
Steve
Dan H. M. avatar
Any old UV/IR cut filter should work.  What matters more is the size of the filter because the RASA has such a big light cone, and you will want to avoid reflections.  I would think a 36mm filter would work but you may want to try a 2".  Either is very affordable.
Well written Concise
Steve Spring avatar
Thanks for answering. I was thinking about the incident angle and bandshift and did think I was probably worrying too much when I couldn't find any info out there.
Arnie avatar
Steve:
Angle of incidence is only a consideration for narrowband filters (Ha, Oiii, Sii, etc) where if the angle is too far off from what the filter is designed to pass, some of your light will cut off, with more an more being lost the farther off the angle is. Not a concern with broadband filters (R, G, B) or rejection filters (IR/UV block).
Arnie
Rodrigo Roesch avatar
I use a 2” filter with my RASA 8 when using my color camera ASI 294mc. I think, without the filter you may get blotted stars
Steve Spring avatar
Thanks everyone for your replies and explanations, much appreciated
Well written Respectful
UV/IR Cut Filters - Advice Please!
Hi folks: After recently working with data with more natural colour stars than I am able to get from my Optolong L-Pro even after SPCC, I've been rethinking my broadband imaging filter choice. I live in Bortle 7, and currently image with an Astro...
UV/IR cut filter advice directly relevant to ASI533mc camera setup.
Aug 27, 2024
ASI 533 MC Pro Uv/ IR cut
I would appreciate any feedback regarding the use of a UV/ IR cut filter on an ASI 533 MC Pro camera. If I add a Baader UV/IR cut filter as 'semi-permanent' screw-on to camera does this equate to the 2600MC out of the box? The screw in filter...
Discusses UV/IR cut filter use specifically with ASI 533 MC Pro camera.
Mar 28, 2024
Correct White balance for 585MC to avoid green tinge output
Hi, I have been using ZWO ASI 585MC for a few DSO imaging sessions with various filters like UV/IR cut, Orion Skyglow, Optolong L-Pro etc. While using filters I found the stacked images from DSS come out heavily Green tinge saturated. Even when I try...
Addresses UV/IR cut filter use with ZWO ASI camera for DSO imaging.
Mar 7, 2024
