Daniel Renner avatar
When I started imaging with my ASI 1600 mm pro I always used Unity gain (139) and offset 50. But recently I have read threads of doing 200 for NB and 75/76 for rgb stars so I have also tried this approach. And I use unity gain for broadband targets.
I usually go for 300s on NB and around 120-180 on broadband, depending on how much im clipping.  Do you think this is a good approach? or should I change anything?
(I live in a borte 5-6 zone)
Also some people using gain 76 and some use gain 75, does that really matter?
Andy Wray avatar
I've just used unity gain across the board and then adjusted the exposure times to hit a target ADU.  The only other gain I use is gain 0 for the flats as my LED flat panel (even at its lowest setting) is too bright at unity gain with two t-shirts.
Andy Wray:
*** doesn't the gain need to be the same as your lights? ***
Andy Wray avatar
Daniel Renner:
Andy Wray:
I don't believe so as flats are a division rather than a subtraction function ... darks and flat darks definitely have to be at the same gain and offset as their respective lights and flats.
James avatar
I use a 1600mm in a bortle 5 and have been using gain 76 for broadband and gain 139 for narrow band.  I selected those values because it seemed to be the values other folks with very nice images are using.   Its been working for me.  On exposure.. depending on the target,  lum is anywhere from 120 to 180".  RGB is 180-240".  Narrowband I use 600".
Dan H. M. avatar
I don't see any reason to use anything higher than gain 0 for LRGB on the ASI1600.  The ASI1600's base read noise is 3.5 e-, which is extremely low.  My personal suspicion is that the "Gain 76" advice came about because people were obsessively trying to reach minimal read noise when the camera was still new.  Now everyone is using CMOS cameras and experienced imagers regularly take 3.5 e- read noise or higher to take advantage of the higher FWC.
Vaughan avatar
Very interesting and I had not considered this.  For the past two years I have been using Gain 0 for LRGB and NB.  My LRGB images were good with low noise and decent SNR, such that I have great Cluster images.  However, my NB images were lack lustre.
I've recently switched to Gain 139 (Unity).  Now, the NB are great, but LRGB are suffering, because I've had to reduce the exposure time to compensate for the added sensor sensitivity.
So, my take-away here is LRGB at Gain 0, NB at Gain 139.  Does that sound right?
Although I've been doing this for two years, I still consider myself as a beginner and still on the steep side of the learning curve   BTW my ASI1600MM Pro is through my SkyWatcher Esprit 100ED, which I find is a great match - maybe not the best, but certainly ideal for me.
Dan H. M. avatar
Vaughan:
0 for LRGB and 139 for NB definitely sound right.  NB gain can probably be tweaked a bit but 139 should be perfectly adequate.
Wanderer astro flat panel V4 - weird numbers with NINA
Hi guys. Recently I bought a Wanderer astro flat panel V4 for my FRA 400 that will go remote in september. Last night I finally installed it and got a chance to put it to work with NINA. I obtained some strange exp time / brightness numbers and I'...
Discusses flat panel setup; author focuses on gain/offset optimization strategy.
Jun 13, 2024
