Sh2-132 Hubble Palette
18 replies504 views
Rodd Dryfoos avatar
I have spent allot of time working on this image.  People have told me that likes do not reflect image quality.  I have trouble believing this.  How else to judge an image? Comments of praise are another way, and all the great images that get alot of likes also get alot of comments.  Since I have very few of either, there must be something wrong with this image.  Please provide CC so that I can improve it and subsequent images.  There are a lot of versions--most have very subtle variations.  No need to inspect them all.  This one is the final version
i appreciate any help you may give.
TOA 130 with ASI 1600 and 3nm Astrodon filters
Ha: 124 300 sec, OIII 107 300 sec, SII: 32 300 sec.
Iosif Bodnariu avatar
Hi Rodd. The image is excellent, it has details. you can work with it even if it is jpg. I have tried in my own way to see what I can do, and it allows many processes.
It is very nice to see that Blue ray, this denotes a good processing and acquisition.
As shown in your gallery, you are an expert, and first of all you have to like yourself.
With your permission, I post a test of mine, and a bad image does not allow the stars to be removed correctly.
I think you know how it turned out. Your honest image is very ok. I like it.
Rodd Dryfoos avatar
I
Iosif Bodnariu:
With your permission, I post a test of mine, and a bad image does not allow the stars to be removed correctly.I think you know how it turned out. Your honest image is very ok. I like it.
Thanks Iosif.  You starless image is very interesting. If I am not mistaken that is a photoshop technique, correct?    I have tried to remove stars in Pixinsight but was only partially successful. Thanks for your comments!
Rodd
No, starless is an module in Pixinsight, find it in PixInsight forum, if you don't find this module i'll sent it to you.
Here you have the link. Is verry easy to work with it.
https://pixinsight.com/forum/index.php?topic=13691.0Have an good day.
Rodd Dryfoos avatar
Iosif Bodnariu:
No, starless is an module in Pixinsight, find it in PixInsight forum, if you don't find this module i'll sent it to you.Here you have the link. Is verry easy to work with it.
Wow I did not know pixinsight had that.  Thanks!
Michael Timm avatar
Rodd, your image is great and i would be really proud of it if i were in your place. I told you before that you will never get a "like" from my side as long as you do not provide your acquisition details in the search fields. AstroBins `database believes that this image has not seen any integration time at all. All my filters and searches are based on that fact, so i never get to see any of your images -> i will never like one nor comment anything.
Rodd Dryfoos:
Why not spend 5 minutes more and add your acquisition details?
Rodd Dryfoos avatar
Michael Timm:
Rodd Dryfoos:
The acquisition details are in my page with the image. I input my gear as someone once suggested I do. I did not realize that there was another page for acquisition. That seems a bit much since the acquisition details are in my comments.
Rodd Dryfoos avatar
Here is my point.   152 people have seen this image. About 1/3 liked it.  Based on my other images, these numbers will likely top out at 300 looks and 70-110 likes after about a year.  To me that sounds like people think the image is lacking in something.
Rodd
Michael Timm avatar
Rodd Dryfoos:
It's just my point, you can put the acquisition details wherever you want. I am just saying that all of my searches contain something like "integration time > 0 hours". If you put the integration time only in the description, the database does not know about it and i will not see your image.
Look at this example:
M 42
If you look right under the image AstroBin tells you that i imaged 3 hours in total. 2 hours with 5 min subs and 1 hour with 1 min subs. I know that you also provide this information in your description, but the description is only human-readable, not machine-readable, so my search won't show me any of your images :-(
Helpful Insightful Respectful
Rodd Dryfoos avatar
Michael Timm:
Rodd Dryfoos:
M 42
If you look right under the image Astrobin tells you that i imaged 3 hours in total. 2 hours with 5 min subs and 1 hour with 1 min subs. I know that you also provide this information in your description, but the description is only human-readable, not machine-readable, so my search won't show me any of your images :-(
You actually search based on integration time?  I usually search based on target name (or designation), or scope, or camera (rarely).  But integration time....I have never done that.  Interesting.  I will endeavor to populate the acquisition fields for my images--quite a project for over 100 .  Unlike the gear, using the copy function won't work as the integration times are usually different for every image as apposed to gear--which is limitred to 4 set ups for me (and I stick with one for extended periods so really just one for long stretches)
Rodd
Rodd Dryfoos avatar
Rodd Dryfoos:
It's just my point, you can put the acquisition details wherever you want. I am just saying that all of my searches contain something like "integration time > 0 hours". If you put the integration time only in the description, the database does not know about it and i will not see your image.Look at this example:
M 42
Now that I look, each filter has its own page--sorry, but that is ridiculous.  On DSO (Telescopius now) you can fill all filters and gear and acquisition times on one form.  I am sorry, but I am not likely to input four pages for my acquisition details.  I don't think many people search by aquisition details.
Rodd
Rodd Dryfoos avatar
Rodd Dryfoos:
M 42
I just tried to add filters to my gear (only the Ha is on the list)--but I could not find how to do it.     Without all filters, I can't input the acquisition details
VuurEnVlam avatar
I've AB in Italian so something could be lost in the translation, anyway:
- click on the small button near the big button with your name/nick on the right-top of the page ( the one with the small arrow that points down )
- MySettings/Settings ( last entry before 'logout' )
- On the left panel choose instrumentation/gear ( strumentazione in italian ), the second entry.
- Here you should have the 'filters' section ( right before the last entry, 'software' )
Rodd Dryfoos avatar
I've AB in Italian so something could be lost in the translation, anyway:- click on the small button near the big button with your name/nick on the right-top of the page ( the one with the small arrow that points down )
Grazie Tante!  I will have a look.
Rodd
VuurEnVlam avatar
Prego  smile
Ciao,
Stefano.
Rodd Dryfoos avatar
Rodd Dryfoos:
OK Michael--I have input my integration time--Thanks to Stefano I was able to add filters.  Now I will populate the acquisition details for al my images over the next couple of weeks.  Thanks for the feed back
Rodd
Rodd Dryfoos avatar
Michael Timm:
I botched the quote process Michael and quoted myself--meant for you.  see my last post
Rodd
Michael Timm avatar
Rodd Dryfoos:
You actually search based on integration time?  I usually search based on target name (or designation), or scope, or camera (rarely).  But integration time….
Just to clarify: Of course i search for target names or specific equipment or something else. I just filter all results so i do not see all those images lacking basic informations (like scope, camera or even integration time).
Rodd Dryfoos:
OK Michael–I have input my integration time–Thanks to Stefano I was able to add filters.  Now I will populate the acquisition details for al my images over the next couple of weeks.
I am very happy to hear that! This is one important difference between facebook and AstroBin: The ability to search - based on a well designed database. Thanks for participating, Rodd
Rodd Dryfoos avatar
Michael Timm:
I am very happy to hear that! This is one important difference between facebook and AstroBin: The ability to search - based on a well designed database. Thanks for participating, Rodd smile
I do find it very frustrating to search for a target for planning purposes and no scope or camera is listed, so I can understand integration times being important.  For some targets I suppose they are critical.
Rodd
First Narrowband Targets
Going to be doing some narrowband imaging next week. First time for this for me. Will use ZWO ASI 1600 mm and ZWO Sii, H alpha, Oiii filters, all 7 nm band. Can folks recommend some easy targets to start with, maybe 10 or so? JonS
Sh2-132 Hubble Palette narrowband imaging example; directly relevant to author's first narrowband session.
Mar 24, 2019
M13
I have been trying for a long time to decide which version of my M13 I should call the final. I have dozens upon dozens of versions beyond what is posted on Astrobin. I am trying for a realistic look–so not too much saturation, as much resoluti...
Author seeking feedback on multiple versions to select final image.
Aug 16, 2021
First takes and questions on dedicated CMOS after 10y with DSLRs (dithering, flat, flattener)
Dear Friends, I am in Astrophotography for almost a decade and was using DSLRs only but changed to a dedicated CMOS camera lately. So here are some thoughts and questions regarding my first experiences. The very first image I took I was struck with m...
Technical guidance on camera settings and processing for image quality.
Jan 20, 2021
FWHM
For long have I relied on FWHM as a tool for focusing as well as to decide if subs were keepers, if seeing any any night was good enough to image. But I wonder if FWHM really has much significance. Other attributes such a SNR, median values, noise, e...
Focus and image quality assessment tools relevant to improving results.
Oct 8, 2020
