Best approach for collecting data of same target with different camera
3 replies215 views
[deleted]
Me and two friends have decided to take a cooperative picture of a single target (there's still pending discussion about which one).
The cool thing is that we have quite different sensors but the same focal length. Here's the situation:
  • Sky_watcher 80ED with 0.85 focal reducer
    • ASI 2600MM Pro (Ha, L, R, G, B filters available); Bortle 4
    • ASI 183 MC Pro
      • One will use L-Pro filter as the photograph resides under heavy Bortle Sky (like 8 I guess)
      • The other can easy shot without any filter (Bortle 4)
How can we optimise shooting regarding our respective setup?
Intuitively, I would focus the monochrome on L and/or Ha data but what about OSC?
Blending all that together will also be challenging but I'm really excited about it!
Many thanks in advance for your precious advices.
Carastro avatar
The best thing is to make sure both your cameras are orientated the same, then all you will have to do later is a Crop on the largest FOV.
I have often combined data from different set ups and provided the target does not have much rotation in repsect to the different cameras I simply use Registering software to re-size them to each other.
Carole
Vasile Unguru avatar
Hi Francois,
I think there is a huge difference between this two cameras. 2600mm with 2 hours on every filters L/R/G/B will be miles ahead of many hours exposed with the 183.
But, this doesn't mean that it can't be done. i would use 2600mm with L for luminance and optional Ha filters and no reducer. the 183 OSC + 0.85 reducer  can collect color data.
I dont think to be difficult to combine all data together; you will have 2 separate integrations (but keep them registered/alligned to each other) one OSC and one mono luminance. process them separately and at the end just layer luminance on top of the color.
this was anyway my workflow when i was using two scopes/cameras working in parallel on the same target.
Of course a lot depends on the target you choose. Much greater and quicker result will be to shoot predominantly nebulae mono Ha with 2600mm and color data with the 183 (preferably with a duoband filter).
Anyhow, good luck and clear skies!
Vasile
In general you'd want to shoot the Luminance or H-alpha frames at the settings that give you the most advantageous SNR and the best possible resolution and the colour frames with an FOV that encloses that of the L/H-alpha frames.
A new monochrome CMOS by ZWO
The ASI294MM Pro is now available which appears to be an upgrade to the excellent ASI1600MM Pro. This group would be a great place to display your images and discuss techniques using this camera.
Cooperative imaging with different cameras relevant to ASI294MM Pro users.
Oct 16, 2020
Despite a correct Flange focal distance (FFD), the focuser remains without effect... Why is that?
Hello, For a few years, I have been shooting astrophotos with a Nikon D610. I bought at the beginning of 2020 a NIKKOR 70-300mm f/4.5-5.6E ED VR lens. Then I decided to upgrade my setup. I equipped myself more seriously (AZEQ6 mount, QHYCCD 294M came...
Author collecting data with different camera/scope combinations; similar cooperative approach.
Apr 2, 2021
Luminance Subframes Degrade Color Images' Resolution (A demo and explanation of why)
Luminance Subframes Degrade Color Images' Resolution Alex Woronow, 2024 Introduction Luminance subs were collected in ancient times to improve signal-to-noise and to "provide" detail when color (RGB) subs were collected in 2x2 binning t...
Discusses luminance filter usage and color imaging, relevant to L-Pro filter strategy.
May 13, 2024
