RGB acquisition strategy
11 replies449 views
Frédéric Auchère avatar
That's it, four years after (re) starting astrophotography with an EOS 6D and camera lens, I finally bought a dedicated mono camera (ASI2600) smile
What are the pros and cons of the various possible ways to spread the RGB acquisitions over night: all Rs then all Gs then all Bs, alternate RGB every other N images, Nxr, NxG, NxB & repeat? I suppose I should not be taking the Gs & Bs too close to the horizon. Maybe also there's an advantage in not doing each channel in one block to even out sky conditions?
I don't have many clear nights so although I'll try to image a target over several nights, I'd like to secure at least one complete RGB set per night, so I'm excluding taking one filter per night.
I'll typically be taking 2 minute long subs. I'm currently thinking of looping through 1 hour runs in each band. Any suggestion?
Frédéric
Not that makes much of a difference but I'd collect the RGB frames in the most clear nights with the worst seeing one colour band after another in one go.
Ron avatar
I started by changing the filters after each shot - the idea being if I only managed a short period of time, I would have all the colors to make an image.  In doing so, I relied on the filters being parfocal, which they really aren't even though they are "supposed" to be.  But I did get a "full color" picture when I went out.
Once I got an electronic focuser is when I found that filters aren't as parfocal as claimed and I began automatically refocusing every hour.  By refocusing each filter, I find that my data is now much better than it had been.  Now I shoot at least an hour in one color before changing to another.  If needed, I capture other colors on additional nights.
Now if I could just improve my processing . . .
Ron
starfield avatar
A lot for me depends on the weather and time window.    I typically will shoot all my R, G, B and L in one shot.  I often will try and arrange my sequence so I'm shooting my Lum when the target is the highest in the sky.      Sometimes I will split my RGB up into smaller sets of 10 frames each, just to collect a mix of data at different altitudes and also use this if there's a chance of clouds rolling in.    I avoid shooting single frames just because my normal focus routine is to run an autofocus on each filter change and that would add a lot of overhead.
Helpful Insightful
Andy Wray avatar
That's a great question and has got me thinking:
Up until now I have done 60 frames of Lum and 20 frames of each RGB filter in a loop with autofocus on filter change.  I might get two loops in an evening typically.
Having seen these posts, I will move from LRGB order to RGBL.
Ron:
That's exactly why I want to do not too long blocks in each filter in case bad weather or technical issues creep in.
Ron:
I don't have a focuser yet, so I figured I'll refocus at each filter change, like you every hour.
Ron:
Nice gallery
I thought that could make a difference. Do you see one?
Sean van Drogen avatar
Tend to collect 3:1:1:1 LRGB, invested some time in getting good filter offsets in my system. This way with NINA I tend to do the following loop.
15x 60s Lum
5x180s R
5x180S G
5x180s B
and let it run from asto dark to astro dawn
Similarly trying as @starfield get subs at different altitude levels. Have not tested what difference it makes if any but instinctively feels like the right approach.
CS Sean
starfield avatar
Frédéric Auchère:
I do to the extent that subs collected closer to the horizon have stronger gradients.    Normalization probably takes care of most of this so not sure if I've seen a big impact.
Karl Theberge avatar
In NINA I use Dark Archon plugging to calculate the offset of each filter then you can run the channel one after the other without refocussing.
Also, just do a focus run every X RGB cycle or time.  I personaly use HFR difference for my focus run so it only refocus if there is a need to do so.
Karl
Leonardo Landi avatar
I usually shoot RGB in the same sequence in order to optimize my dithering. My rgb sequence is
5x40s G
​​5x40s R
5x40s B
Dither
Loop until nautical dawn.
You need a software like Nina to do so and an electronic focuser with filter offset.
Local normalization will benefit of the frames taken at higher altitude.
I shoot L on different nights with perfect conditions.
Thank you all for the feedback! A motorized focuser is definitely on my Christmas list smile
Now the hard part: a clear night at my countryside site smile
F
Tracking issues after meridian flip
Hi everyone, Been a little over a year into my astrophotography hobby and I've dove head first. Upgraded my mount from the EQM-35 pro to the AM5 a few months ago and I love the ease of use. I also upgraded my scope to the Astro-Tech 130EDT from m...
Sep 29, 2023
Both posts describe astrophotographers sharing their recent equipment upgrades and seeking or reflecting on best practices for their hobby.
One year of remote imaging
It is just over one year that I started to use a remote hosting facility in Spain and installed one of my telescopes there. In earlier blogs I have written a lot about the journey how to get there. I thought it might be a nice idea to write a fifth a...
May 7, 2025
Both posts describe personal milestones in advancing their astrophotography setups and practices.
New to or Considering Astrophotography/astronomy?
I had posted this with a new image I’d uploaded as a change from the “typical” review of my processing steps/acquisition. A friend/commentor suggested I post in a forum, so this is the result. This is VERY subjective and based entirely on my experien...
Jul 31, 2025
Both posts discuss practical considerations and decision-making strategies for astrophotography beginners and those transitioning to new equipment or techniques.
DIY Strain Wave Mount
After making my first star tracker, I immediately started to wonder about making a goto mount. The tracker took me a year and a half with several drivetrain configurations and lots of lessons learned. This Big Ballhead GoTo Mount took less than half ...
Feb 23, 2026
Both posts describe astrophotography equipment upgrades and the technical considerations involved in capturing astronomical images.
Calibrate or not to calibrate RGB filters
Question for the Experts Hi, Looong time ago when I started with astrophotography >25 years we used to calibrate the RGB filters exposing on a G2V star (similar to sun) and we got ratios like R = 1.00000 G = 0.73260 B = 0.84388 Nowadays having PI ...
Nov 28, 2025
Both posts discuss strategies for acquiring and processing RGB color channel data in astrophotography.
