Yet another backfocus question
2 replies185 views
deleted avatar
I notice that when I focus in or out slightly, the star shapes change from the comet shape to the crescent shape at the edges of the frame.  The shapes change consistently so it's not tilt, and my OTA is collimated.  When I saw the comet shapes I thought okay too close add some space.  I changed the 5mm spacer at the front of my train (that threads onto my reducer corrector) to an 8mm spacer.  Then I got crescent shapes when the stars were slightly out of focus.  When I ran the autofocus routine in NINA, it completed, then the stars became comets.  Has anyone ever experienced this?
kuechlew avatar
The in focus star shape is the relevant one to judge your backfocus. If you shift the plane of focus while you are close to the proper backfocus what you experienced can happen. Instead of just trying out you could ask the vendor or the community for the expected backfocus of your setup. For sure you will need to increase backfocus further based on what you told us.
Good luck and clear skies
Wolfgang
Concise
Björn Arnold avatar
Don't trust star shapes regarding back focus. For the "simple" case where tilt and all other parameters are fine, you can check your backfocus by this simple method:
Center a fairly bright star and focus it. Move the star into a corner. Check if you need to move the focuser in or out in order to get the star focused. If you need to move it in, your working distance is too short and you need to add a bit. If you need to move the focuser out to get the star in focus, you're too far away from the reduer/flattener and need to get closer.
Björn
27% Tilt on my Celestron Imaging Train
Switching over to a longer focal length setup for galaxy season. Was using a WO GT81 refractor and an imaging train consisting of a WO refractor reducer/ corrector, filter wheel, tilt plate, spacers and a ZWO AS294MC Pro. I used ASTAP to check for ti...
Discusses imaging train spacing issues affecting star shapes at frame edges.
Feb 16, 2024
Doubled bhatinov spikes.
An interesting thing happened last night. I got double bhatinov spikes on my edge hd 8. my backspacing was previously 104-ish, and everything was ok for the most part but i figured i would try to increase backspacing to the more reported 105ish. To d...
Addresses backspacing problems causing doubled/distorted star shapes during focusing.
Mar 22, 2024
