question about William optics adjustable Flat 73A for WO Z73
6 replies479 views
Richard O avatar
hi all,  i am having a bit of trouble finding an answer to this question. i have the wo z73 as well as the adjustable flattener for it. it says in the specs that the back adjust for the flattener is 11.4mm. My question is that is that measurement for the scope, or for dslr?.. since i am using a zwo 183mm.. i am unsure where to place the adjustment on the flattener.. i know the camera requires 55mm and i can cover that i just cannot find any info for the flattener part.  any help would be greatly appreciated. smile
Robert Q. Kimball avatar
I don't have the a specific answer, but I do have experience with a W.O. FLT 110 and W.O. AFR IV flattener.  On the flattener, there are numbers from 68 to 88 (i think, my scope is up at an observatory.  The distance from the back if the flattener to the sensor + the value on the flattener needs to add up to 123.5 mm.   I suggest you contact W.O. and see if there is an Iideal distance for your flattener.
Bob
Chris avatar
I have the z73 also but using it with a ZWO asi178mmcamera.  This is the arrangement that I used:
ZWO ASI 178 Back Focus
The "filter" listed in the diagram is the zwo filter wheel, but a spacer replace it.  I've had good results with this setup. I am not sure if the asi 183 sensor spacing to the body is the same.
Chris
Concise
Juan Pablo avatar
Richard O:
Hi Richard,
I have your same setup, but I can't find the correct configuration, can you help me?,
cheers.
J
matthew.maclean avatar
Hi Richard,
if you go onto  to the WO website for your flattener, they have a little BackFocus schematic under the “MoreInformation” tab. Looks like your camera plane needs to be (Dimension.A) 66.2mm from the back edge when it’s at zero. So the 11mm value they quote would be for a DSLR; with an Astro Camera, you just need to accumulate that total distance using the flattener, extension spacers, filter wheel, camera flange, etc.
if you are using filters, the glass affects the spacing slightly. Usually you have to add something around 0.7mm or so (depends on the manufacturer).
Richard O avatar
hi all thanks for the replies… i am currently still looking for the best adjustment for this but since i have started a new job that requires me to travel every 3 months and finding clear days when i can, it has been rather difficult to get time under the sky. I will keep working on this though and see what i can come up with. but starting point of 11.4mm on the flattener was a good starting point.
Jonathan Aranow avatar
I had to sort out a similar issue with my WO z103 and asi1600 and filter. I emailed WO and got a response in a few hours. You do need to go to zwo site and look up specs for your camera for its back focuslength.
need a little help with William Optics Flat73R
I am having a devil of a time trying to get my field totally flat. now i am using a zwo asi183mm pro with the william optics z73 with flat 73r and a filter wheel. it said to adjust the ring back 1.8mm for a camera with 17.5mm backfocus.. i did and no...
Same scope, flattener, and camera model; directly addresses back focus adjustment.
Oct 17, 2020
Field Flattener for Skywatcher 120ED Evostar
I have a second hand ED120 I have just purchased and wondered if my existing flattener for my ED80 would work with it? If not, are there any alternatives to the Skywatcher 0.85 flattener/reducer that would be recommended? (Ideally a flattener and not...
Directly addresses flattener compatibility question for specific telescope models.
Aug 20, 2018
First takes and questions on dedicated CMOS after 10y with DSLRs (dithering, flat, flattener)
Dear Friends, I am in Astrophotography for almost a decade and was using DSLRs only but changed to a dedicated CMOS camera lately. So here are some thoughts and questions regarding my first experiences. The very first image I took I was struck with m...
Discusses flattener setup with dedicated CMOS camera; relevant to back focus configuration.
Jan 20, 2021
