Do flats help with collimation?
3 replies267 views
Andy Wray avatar
I've been using the FlatContourPlot in Pixinsight recently and wondered if it helps to understand how well collimated I am.  Below is an example. Clearly I am slightly off in two dimensions.  I just wondered if any of you use that script and what your plots look like?
Well written Engaging
Max Gillet avatar
Flat will just show you if the frame is correctly illuminated (which it is according to yours) however it will not show you if your collimation is perfect, which you can be seen by a lower sharpness of the stars.
Max
Andrea Alessandrelli avatar
Not in a Newtonian. It's about secondary mirror placement. On my GSO 6'', I used to take flats to check the field illumination and work on the spider vanes adjustment knobs and the secondary mirror center screw until the illumation was even.
Yuxuan avatar
I would say indirectly. For a Cassegrain if your secondary is perfectly centered, then the centering of illumination can tell you if the optics is collimated. However, if your secondary is not perfectly centered, say off by just a few millimeters, you can still
be perfectly collimated (if your secondary mirror is spherical) but in that case the field illumination will not be centered.
There are many other factors too. The uneven illumination can be caused by your filter, and the camera sensor tilt and displacement, etc. I have a perfectly collimated iDK but the illumination is never dead centered.
Hotech Advanced CT Laser Collimator - What is causing this?
Greetings, I purchased the Hotech CT Collimator and have had a difficult time getting good results with it. I have watched the instruction videos multiple times over and I think I understand the concept well, but my collimation still suffers. My use ...
Discusses collimator use and collimation challenges relevant to author's inquiry.
May 2, 2024
Pinched optics, backspacing error....or both?
I managed about two hours of imaging last night with my R200SS and have very quickly processed the images this morning; 40 x 180" frames. I've been using the scope for years now, so have the backspacing sussed (I think) and collimation is ok...
Addresses optical issues including collimation problems affecting image quality.
Jul 17, 2024
17 things I did during the last year to greatly improve my astrophotography
17 things that I did in the last year that improved my astrophotography. Hi, I am an amateur astrophotographer. I have spent about 10 years doddling with it, even taking a 3-year break during the pandemic due to work commitments. I came back to it in...
Covers astrophotography improvements including potential collimation optimization techniques.
May 22, 2024
GUIDE: Collimating Takahashi Epsilon 130 ED w/ OCAL
We all know the reputation these scopes have when it comes to collimation. As a former RC owner I always wondered if collimation was really that difficult on an Epsilon or if people just aren't using the correct method. I've owned an OCAL v2 ...
Directly relevant guide on collimating telescopes for better results.
May 13, 2024
Dirty mirror or poor seeing or faulty processing ?
Dear fellow astrophotographers Along my journey to better images, where progress goes hand in hand with increased expectations and discoveries of new imperfections, I am wondering what is wrong with my stars and in particular whether the grey aura ar...
Discusses image quality issues that could relate to collimation problems.
Feb 21, 2024
