Which Barlow ?
16 replies350 views
Planetarios_3 avatar
I'm seeking a barlow lense for my equimpent (C 9.25 and asi 290mm)
Can anyone give me advice which would be suitable for my system ?
Werner
Adel Kildeev avatar
I would suggest Celestron 2” x2.5 Barlow (very good quality). Theoretically you can  try x3 and even x5, but for SC (not APO) it may be too much (I tried x5 Bresser with my Meade 8” ACF - no good results.  smile
Hi Adel,thnakx fpr the tip…I`ll see… smile
I think maybe a tele vue barlow 2.5x … of the quality should they be superior to various opinions of the celestron?
I don*t know if its true
Werner
Adel Kildeev avatar
I think maybe a tele vue barlow 2.5x ... of the quality should they be superior to various opinions of the celestron?I don*t know if its true
Werner
You usually get that you paid for  ;)  You may get best results with APO barlow, Tele Vue and Bresser are great but quite expensive
Almost clear….the more expensive the better the quality
Rod Kennedy avatar
Without question the Tele Vue Powermate 2.5x gives superior results. Rod
thanx rod
dzurron avatar
I agree with Rod.  I have been using mine for the past year on my 10" SCT.  Image quality is amazing.
Jeff Coldrey avatar
Depends a bit on your seeing conditions.
When using a C9.25, I found a Powermate 2x to be excellent, but a 4x was too much.
Well Written Concise
thanks jeff,
yes i know 3x is too much too…perhaps 2.5 is ok (only when seeing is good)
astropical avatar
Hello Planetarios_3,
I would opt for a 2x or 2.5x which is at least a 3-element fully multi-coated barlow.
They are available at under 100 USD (for instance GSO brands).
Note that when you sandwich a, say, 2x barlow between focuser and
diagonal the magnification will be 3x :-)  A matter of seeing (and budget).
All the best,
Robert
Thanks for the tip robert smile
Now I have the opportunity to buy a (used) TV powermate 2.5 … I'm afraid that this is too much for my system (c 9.25 and asi 290mm and two filter wheel) (oversampling?)
Can anyone help me in this regard
Thank you
Werner
astropical avatar
Hello Werner,
Even without a barlow oversampling will occur anyway at FL=2350mm in combination with an ASI290MM, but no big issue with accurate guiding and good seeing when imaging moon and planets (undersampling would be much worse). You can always compensate a bit for oversampling by 2x2 binning your ASI290MM.
I don't know what the used 2.5x Powermate will cost you, but I'd assume this is a rare opportunity and you can also enjoy its fine optics for visual.
Since this is a subjective view, please expect other opinions before you buy.
Cheers
Robert
Well Written Helpful Insightful Respectful
thanks Robert for the tip with 2x2 binning
cs
Werner
Tareq Abdulla avatar
Why not Powermate 2x instead? that will serve you more than PM 2.5x, i can buy 2.5x or all Powermate models because i have more system than you to use with, and for now i am using 2x for my Mak and 5x later for my 8" Newtonian and also upcoming 20" Dob in future, but i am planning to buy 4x first and then 2.5x just to have the collection whenever i need.
New to SCTs
I'm looking at getting an Edge HD 9.25 in the near future, if they ever get back in stock, and was looking for some advice. I currently have a CEM60 mount and would be imaging with either an ASI1600MM, ASI178MM, or ASI224MC. When I get the scope,...
Discusses SCT telescopes; author has C 9.25 which is an SCT model.
Sep 29, 2020
Question about optics : Barlow and extension tubes
Hi All, I hope some people having good knowledge in optics will help me : I have bought a 4x Powermate and need to use some extension tubes to be able to focus. On my setup I have connected the Barlow directly to refractor, and then the filter wheel ...
Directly addresses Barlow lenses and extension tubes for optics optimization.
Jan 30, 2021
buying advice for first planetary camera for C8
Hi All, I was recommended to buy the ASI178MC to use with my C8 based on fact that it had the highest resolution (6.4MB) when compared to ASI224MC (1.2) and ASI462MC (2.1). However, using astronomy.tools/calculators/field_of_view/ it seems like the s...
Discusses camera selection for C8 telescope; relevant to SCT equipment setup.
Sep 27, 2020
