How to add new equipment???
2 replies•203 views
Jens Mascher avatar
Hi friends!
Today I tried to add a new telescope to my equipment list. But I cannot find any "add" button, also the explorer could not help me.
I am nuts or is there any trick to get added the new gear?
Thanks in advance!
Jens
matthew.maclean avatar
Hi Jens,
Just start typing the name of the telescope you want to add in the box (start with the brand name first). Astrobin will give you choices of telescopes that already exist that are similar to what you are typing. At the very bottom of the list, there is an orange button "Create new" if none of the existing choices are applicable to what you have.
Edit: I should clarify - when you are uploading a new image (Edit > Content > Equipment), this applies. Anything you have added to any image will appear on the summary list in your settings.
Well Written Helpful
Jens Mascher avatar
Thanks for the advice!
I noted, that AB adds also new equipment if in my list I upload new images and use the search database function ;-)
This topic is closed to new replies.
