I have a crazy idea, but one Ive thought a lot about. I have a Televue NP 127is mounted on my AP Mach 1 GTO for imaging. The setup works great and has for a long time. As this is my only GEM Mount, I do some visual obs by setting up an alt-az rig with my Berliebach, DMQ6 and my Mewlon 180. I like to observe the moon and planets visually and only use my TV 127 for DSOs.
I bought an ADM side by side dovetail system. The plan is to mount my Mewlon 180 side by side with the NP127. That way I can use my mount for both imaging when I have the itch, or for visual. I can leave the imaging train set up as always and enjoy some visual, or, even while imaging I should be able to use the Mewlon for visual of the general region I am imaging. I think my AP Mach 1 is perfectly capable of handling the weight, if I balance it properly. Total weight is under 40lbs. and everyone talks about the Mach 1 being able to handle much more, even for imaging.
This may not work and I haven't changed everything yet. Does ANyone have any thoughts or comments on this crazy idea? Thanks
Jeff
Jeff
