Michael Caller avatar
Hi All
Im yet to add data from a previous imaging session from a different year to new data obtained.i cannot find mush info online.
I use Pixinsight & Photoshop for processing is it just a case of registering old and new stacked data to each other and adding via layers ? or do I stack the old stacked data to the new via DSS function stack already stacked images?
look forward to your responses.
Thanks
UN73 avatar
hi,
can´t help you with pixinsight. with dss you can stack the two sessions separately and combine them in layers in photoshop, which can be very fiddly. photoshop has different transformation functions which are usually needed. you can also adjust how much of which layer you want to have in the final image. also useful for combining ha with rgb subs if one is patient.
nowadays i use astro pixel processor. that combines different sessions in one go even if the focal length is different or if there are other issues like a slightly different fov and using a lens which has some optical warping. for adding narrowband to rgb one can adjust how much of what comes into the final image. for just combining different sessions i haven´t found a way to adjust the percentages yet.
i´m sure that pixinsight offers the opportunity to stack different sessions in one go.
bye,
ulf
Steve Milne avatar
You can do it as you say.  My suggestion, however, would be to calibrate the new subs, then get the old  individual calibrated subs, then align them all using StarAlignment and finally re-stack using ImageIntegration.
Well written Concise
hi,can´t help you with pixinsight. with dss you can stack the two sessions separately and combine them in layers in photoshop, which can be very fiddly. photoshop has different transformation functions which are usually needed. you can also adjust how much of which layer you want to have in the final image. also useful for combining ha with rgb subs if one is patient.
bye,
ulf
Thanks UN73 I do have paid version Astro Pixel Processor. iv not really used it since I purchased it but maybe give it a go.
Kevin Morefield avatar
Steve Milne:
Best Advice
Steve Milne:
Thanks Steve sounds very simple. thats why I love PixInsight
Steve Milne avatar
PixInsight and ‘Simple’ ……  smile ????
Steve Milne:
PixInsight and ‘Simple’ ......  ????
Apparently I'm the only one that thinks Pixinsight is Simple
UN73 avatar
Michael Caller:
hi,can´t help you with pixinsight. with dss you can stack the two sessions separately and combine them in layers in photoshop, which can be very fiddly. photoshop has different transformation functions which are usually needed. you can also adjust how much of which layer you want to have in the final image. also useful for combining ha with rgb subs if one is patient.nowadays i use astro pixel processor. that combines different sessions in one go even if the focal length is different or if there are other issues like a slightly different fov and using a lens which has some optical warping. for adding narrowband to rgb one can adjust how much of what comes into the final image. for just combining different sessions i haven´t found a way to adjust the percentages yet.
bye,
ulf
if you go for APP tick "multiple session" under "1) load" and depending on your sessions "same camera and optics" and/or "use dynamic distortion correction" under "4) register"
Carastro avatar
Michael I do this fairly regularly and even combine data captured with different scopes and cameras over different years.
If you are using the same scope and camera it's much more straight forward, as you can stack the data together, but bearing in mind you will have different flats from different set ups I find it best to stack the different sessions separately and then stack the stacks.
If I am using data captured with different kit, then I register them to each other and combine in Photoshop layers, normally 50% in the top layer.  I don't use Pixinsight.
I guess the advice above is probably more useful to you if you are using same kit and Pixinsight.
Carole
Hello from Northwest Indiana
Hi folks, I'm fairly new to astrophotography and even newer to AstroBin. I've had an interest in astronomy since I was a kid gawping at the amazing Hubble images in whatever astronomy books I could find, had a couple of cheap telescopes over ...
Introduces new astrophotographer; lacks specific technical guidance on image registration/stacking.
Nov 10, 2020
Noob advice wanted please
Ladies and Gentlemen, I’ve had a few successful nights capturing lights with my current setup, yet I have been having some issues I’d like some advice about. GEAR: William Optics Zenithstar 81, WO guidescope, ASI294, ASIAir Pro, EQ6-R Pro Mount ISSUE...
Seeks advice on capture issues; doesn't address combining data from different sessions.
Apr 29, 2021
