I think I'm slowly getting there with collimation, but could use some guidance.
* I use a laser collimator that I have made sure is collimated itself. That means I align the secondary to the primary by centering the laser on the primary centre spot. I then align the primary so that the laser is dead down the centre of the collimator. All that is relatively easy.
* I do, however struggle with getting the secondary in exactly the right position and angle on the focus tube. That means that I have uneven vignetting and also weird shaped stars I think due to uneven diffration spikes.
Is it possible that my bad alignment of the secondary would cause uneven spikes and star shapes? It's almost like two out of three of my mirror clamps are causing spikes.
See the below (particularly visible in the larger stars):
M51 with a cheap telescope on a hot summer's night
