Mount Periodic Error
8 replies381 views
Curious to hear about what people think and experience in terms of periodic error.
How do you mitigate it? What physical changes have you made, and maybe some with software.
Let's have a great chat here, about this.
CCDMike avatar
Hi Bill!
PE is an issue you can handle.
First of all there are software solutions to correct this (periodic error control) and furthermore to record the errors and permanent correct them.
If you do guiding the PE is just one more error within the whole system, which is corrected by the guider.
I combined both with my EQ6R (EQMOD) and Phd2 and I am happy with it.
To face PE by hardware would mean you need perfect parts installed in the mount which is really expensive.
Cheers
Mike
Helpful Concise Supportive
Wei-Hao Wang avatar
I avoid mounts with PE larger than about 15" peak-to-peak.  Then below 150mm or so, I can do unguided imaging.  Above 150mm, I auto-guide.
Some mounts with high-resolution encoder can suppress PE to lower than 1". That's nice, but I still auto-guide with such mounts, as there are other kinds of tracking errors (PA error, atmospheric refraction, flexure, etc).
I don't have good experience with PEC so far.
Arun H avatar
Bill,
I own a Mach 1. I  think its native PE was ~ +/- 3" Peak to Peak. I used PEMPRo to reduce it to around +/- 1" Peak to Peak. Recently, I changed the chip on my CP3 which would  cause the mount to lose its  PE curve. What I find is that there is no difference in the guiding performance when I didn't use PE correction.
Wei-Hao Wang:
I have found PEC to work very well in the cases I have used it on. Unguided imaging is very important to me, as I like to maximize the amount of usable data I get each night I image, since I don't get that many clear nights per year at my location. Without PEC or without encoders, unguided imaging would be much more difficult to accomplish.
Guided imaging performance with and without PEC is interesting to think about. I doubt PEC would be super noticable. Maybe slightly lower RMS error in RA?
Scott Lockwood avatar
I too upgraded the chip in my AP1200 and have to redo the PE. Also using PemPro for this. Very nice and simple program that walks you through the process and also has a very good polar alignment program in it for fine tuning down to sub arc sec. My PE peak to peak was 2.8 ARC-SEC before I started but clouds moved in before I could finish. I'll let you know how it turns out.
Scott
Concise
Scott Lockwood:
Scott
PEMPro works great on the mounts I've used it on. My AP400 had the PE go from about 14" to less than 1".
Well Written Concise
Michael Hornfeck avatar
With my EQ6R-pro and WO GT81iv+OAG, my first experience with recording a PEC curve left me with a random spike at the overlap point where the cycle began to repeat. I noticed it in the guiding every time it came around again so I removed the PEC training and figured I would retry it another night, but clear nights have been rare here lately so I haven't been able to try again without wasting imaging time.
After cleaning/re-greasing the tapered roller bearings, reducing the bearing pre-load to be less than stock, and adjusting the backlash, my typical guiding is already about 0.5-0.65"rms depending on seeing/altitude of the target. My absolute worst guiding can be in the 0.8-0.9" range, and my best so far (for only about 30mins) was ~0.35"rms, so I'm already well into the range where I'm pleased with the mount without PPEC enabled.
I'm usually shooting with the GT81 at 385mm so obsessing over achieving <0.5"rms feels kind of pointless, and though I do have a 6SE which could probably benefit from better guiding, I wasn't going to bother changing anything until I came across a program called "PECprep"(that I'm assuming is equivalent to PEMpro). It lets you import PHD2 logs, aligns different individual periods of guiding time, identifies specific mechanical harmonics, performs signal analysis and conditioning, and lets you export a conditioned curve to be used for PPEC training.
I imported my last imaging night's PHD2 logs and according to the "auto filter" analysis, my peak PE was +1.09" to -1.08". If the correction works as expected, it's estimating my residual PE to be +/-0.45" for PHD2 to deal with. It was extremely easy to set up(assuming it works and I didn't overlook something haha), so I figure it's worth a try. All that's needed is to choose your mount from the list or enter its parameters manually, *import your PHD2 log file, hit auto-filter, save the EQMOD output file, and train the mount. I've got it trained for my next night of imaging to see if I notice any changes in my guiding(hopefully positive ones). If not, I can just disable PPEC and try again another night.
*forgot a step
With my iOptron CEM mounts, that I dont have anymore permanent PEC in mount was not compatible with guiding.  Even when I loaded a nice averaged pempro curve into the mount it wasnt good enough to go unguided, so I decided to stop using it.  For the CEM mounts, guiding with PHD PPEC algoritm seemed the best.  I got excellent results with those mounts.
When I upgraded to an AP900 mount, I found that the pempro curve made a tremendous difference.  The mount already had low PE (3.6" peak to peak) but when I recorded a pempro curve and tested, the mount had 0.27" peak to peak.  Thats incredible in my opinion.  With APCC I could easily go unguided if I had to.  I generally guided just because I do think it produced a better result.
Now with my forever mount, the Mach2… I've forgotten what periodic error is… lol.  And guiding as well… whats that?
Long-term Data Storage
Hi all, As technology is always changing, I am curious to know how other AstroBin users are storing their precious photos. Aside from storing them on this site, do you use cloud storage, DVDs, photo development, etc.? Here's what I do: Primary El...
Not relevant; focuses on photo storage rather than periodic error mitigation.
May 27, 2024
Running list of known CDK 14 issues and fixes
I thought I'd fork off the discussion from the other thread and gather a list of things that a new or prospective CDK 14 owner should be aware of. Although it's disappointing that Planewave aren't shipping better OTAs or fixing known issu...
Relevant; CDK 14 issues may include periodic error problems and solutions.
Apr 21, 2024
What is your preferred false-color (or even natural color) narrow band palette?
Since I've been out of the hobby for a while, a lot of things change around me. Its been very intriguing getting back into things, and seeing how people are processing their images today. I've been browsing around ABin, and the orange and blu...
Not relevant; concerns image processing palettes, unrelated to periodic error.
Feb 28, 2024
