My typical setup sequence in the backyard
6 replies390 views
Andy Wray avatar
Just sharing for any beginners out there.  This is typically how I go about setting up and capturing for the night from scratch:
1)  Take the tripod out, put it on my patio and point it as near to north as I can
2)  Level the tripod using it's leg extenders and a standard spirit level
3)  Take out the mount head, attach to the tripod and securely tighten it.  Connect the mount power and control cables
4)  Add the counterweights in roughly the same position on the counterweight bar as the previous session
5)  Add the telescope cradle
6)  Put the telescope (OTA) in the cradle and align it to post-it's that I used to mark the balance points last time I used it.  Also connect all other cables at this point (OAG, camera power and USB etc..)
7)  Fine tune the balance, remembering to remove the OTA lense cap.
8)  Point the OTA as close to the celestial pole as I can guess and wait until dusk plus one hour.
9)  Do an autofocus on stars near the celestial pole.
10)  Use SharpCap to do a polar alignment
11)  Start my telescope/camera control software and cool down the camera
11)  Return the scope to roughly the celestial pole, platesolve and sync
12)  Slew to my target, platesolve, sync and then slew to my target again (I use Goto++ in APT to get me bang on target within 25 pixels)
13)  Start PHD2 and let it do it's calibration stuff and start guiding
14)  Probably do another Goto++ to make sure I am bang on target
15)  Probably do one more autofocus at this point
13)  Start my capturing sequence and go inside for a beer
kuechlew avatar
Thank you for sharing Andy. I can not stress enough how important it is to have checklists, in particular when imaging in the field. Maybe the retired project manager shines through in my case …
I have an equipment checklist which lists each single piece of my setup and I tick it off usually in the morning before an imaging session. Leaves me time to charge a battery if necessary or to search for a replacement part without being in a hurry. For cheap, small and lightweight parts like cables I actually always have spare parts in my bag. You don't want to lose a session only due to a cable malfunction.
Then I have a setup sequence checklist too which specifies in detail which piece goes where in what order. Maybe I'm obsessing a little bit at that point …
Of course I also have a "tear down sequence", it helps not to forget stuff at your stargazing location. Assigning each item a unique place in your backpack helps a lot in this regard too.
In addition I have a post session routine listing all activities to take care about the results of my session and to prepare my equipment for the next session - file backup, charging batteries, checking disk space and the like.
When planing a field trip don't forget to plan for emergency situations. Plan for shelter and appropriate clothing in case of unexpected rough weather conditions, charge your mobile phone to be able to call for help, take a first aid kit with you and inform someone where you are going.
Admittedly it can get a bit overwhelming when you are using different setups for different occasions.
Some important points are  missing in your sequence:
0) Put beer into the refrigerator - otherwise you may run into an issue at the end of your sequence.
18) while enjoying your beer take some time to check the numbering of your sequence smile
Clear skies
Wolfgang
David Nozadze avatar
Hi Andy!
That is a perfect checklist!
I do exactly the same, with just a few tiny differences:
- I connect all cables only after I attach the OTA, just for the safety's sake. There is a risk that my feet may get tangled in the mount's cabling, especially if it is already dark and I am handling my heavy newt in front of me with both of my hands.
- Even before I start assembling the tripod and mount, I alrady take out the OTA, to give it even those extra 10 minutes to adapt to the ambient temperature.
- Once everything is assembled, I cover the rig (Astromania Telescope Cover), to protect it from dust, insect and even possible rain, while I wait for the darkness.
Clear skies!
D
TSS avatar
I am trying to take advantage of the dark skies (Bortle 3) at my recently acquired seasonal campsite around 125 kms north of Toronto, Ontario Canada. I have my focal reducer, camera, focuser, filter wheel, mini pc, dew heater and pegasus powerbox one time installed and wired to by 8" edge HD scope and ready to go. I put the installed assembly on a flat base in a weather proof box for storage when not in use. All I do is connect the 12 v battery to the setup. I have a lot of tall trees in my campsite so I have made a 3 armed trolley with three 8" castor wheels so that I can secure the tripod on it and roll it to the ground with open sky around 50 feet away. I have a bigger 100 ah battery to deliver all the power I need - this sits on a tray on the trolley so no 120V mains power outlet needed. The install I need to do before wheeling it out is :
Install the tripod on the trolley and tie down for transport
Put the mount on the tripod and secure it
Screw up  the QHY polemaster on the mount
Install the preassembled OTA assembly on it
Connect the remaining few usb and power plugs (Polarscope, 12v, hand control)
Roll down the assembly to the open sky
Point mount to the north and level the mount on trolley with the levelling screws - levelling screws lift the wheels off the ground and create a sold foundation
Table + chair + laptop connected to the miniPC by ethernet
Do polar alignment
And I am ready for a night of imaging
I use SGPro for running my imaging session including autofocus after every 4 frames  so all I have to do is wait for the first frame to download check it out and then come back  one in a while to check things out. I set up my alarm for  the early hours of the morning and head back to the trailer. I  then roll my rig back to the trailer in the morning and disasssemble and pack up in my spare time.
Although my setup is very specific for my condtion I hope this info will be helpful to others
Andy Wray avatar
I tend to autofocus on each filter change and then make sure that my sequence is set up so that a filter change happens at least once per hour.  It seems to work well.
Well Written Concise
TSS avatar
Good to know. I have perfocal filters but I think I should try per filter change once to check if the focus changes.
Blaine Gibby avatar
Nice concise setup list. I typically leave my mount and tripod setup +/- the counterweights secured in my back yard, and have all the wires and accessories permanently on my OTA. When it comes time to setup I typically only have to plug 1-2 power cords in and I'm ready to go. Setup is a fraction of the time it used to be.
Problems locating objects
I just bought my ZWO AM5 but I can't get it to move to the coordinates of any object and when I do (with M81) it positions itself in a very wrong direction. I don't have Asiar + so I control it with ASCOM and ASI Mount. The mount connects wit...
Relevant for troubleshooting mount positioning after setup completion.
Mar 28, 2024
Skywatcher AZ-EQ6 mount encoders and EQMOD in conflict
I really like the AZ-EQ6 mount from SkyWatcher, it provides good and stable tracking and guiding even with a heavy payload, but I have a serious problem with the pointing accuracy on the DEC axis that has been puzzling me for more than a year by now....
Setup sequence may help identify pointing accuracy issues in workflow.
Mar 19, 2021
ZWO AM3 and ASCOM drivers
My AM3 mount in remote connects normally with ASI Studio, like the other devices (camera, focuser, filter wheel…) But how to have it slew to a specific object in the sky ? There is no way to do it with ASI Studio. There are many good softwares ...
Relevant for ASCOM driver setup with equatorial mounts.
Jul 5, 2024
Scope now slewing sometimes when starting an imagine session
Having a weird issue where at the beginning of my imaging session sometimes when I use Nina to do framing or to start a sequence, where my mount won't slew. It says it is slewing but it doesn't. I have tried disconnecting / closing NINA and r...
Relevant for diagnosing mount slewing issues during imaging sessions.
Feb 12, 2024
EQ6-R Pro oscillations
I have been the very happy owner of a SkyWatcher EQ6-R Pro for the past 4 years. Until now it has served me well, driving my Esprit 100 and RC8 all round the Southern Sky, on typically one night every four. The mount is remain fixed between sessions ...
Relevant for understanding mount performance and potential oscillation problems.
Jan 14, 2024
