Approach and equipment recommendations for Galaxy Imaging in light polluted city
19 replies817 views
robonrome avatar
I've been imaging seriously for a few years now (well digital… did astro on B&W film in the 80's), all from Bortle 7 backyard and using APO refractors from 400 to 780mm FL using mono and mainly narrowband filters although have LRGB. Main scope now is an APM130/F6 with a 0.75 reducer so running 585mm at F4.5. Main camera ASI2600mm but will ASI294mm still at hand.
Now I have some good experience on low-mid FL and my mount (CEM120) is humming away and performing well I've been thinking about trying my hand at longer focal length imaging (anywhere from 1m to 2m). This could be more highlights of larger nebula and still doing narrowband, but I really would like to see what is possible with galaxy imaging… noting for Galaxies I'd be using LRGB and Ha for accent or maybe even OSC?.
Beyond the above as a stepping point I'm not quite sure which direction to go equipment wise. Seeing here is pretty ordinary, although I'm not really up on how to rate it. Would I be wasting my time at the upper end of this FL range and better selecting  say a 1000-1200 mm F4 Newtonian, or a 8-10-12 inch SC or RC for galaxy imaging? Was thinking starting LRGB and my ASI294mm (larger pixels than the 2600), although also considering whether to revert to OSC for this and just deal with the more severe LP gradients in post… I use APP and Startools for processing, both of which seem pretty good at managing LP at least for LRGB.
Guess I'd just like to hear from others who have taken on the challenge of galaxy imaging from heavy light polluted areas (Bortle 6-7+) and what worked for them in equipment, approach and technique, and what not and why.
many thanks folks.
rob
David Nozadze avatar
Hi Rob,
I think the only way to "compensate" for light pollution in broadband imaging, is to gather 3-4 times more data than you would do under darker skies.
I am "blessed" with Bortle 5 skies above my backyard and don't have much experience shooting under worse conditions. But I am following Cuiv The Lazy Geek and he does galaxy imaging from Tokyo (!), which is the most light-polluted spot on the planet. He uses  8" F/4 newtonian and Edge HD SCT and produced very nice images!
Well Written Helpful Concise Engaging Supportive
robonrome avatar
Thanks David, yes I have seen some of Cuiv's Galaxy imaging videos. He did some nice imaging with an ASI533 osc for Galaxies and using lots of really short exposures 30s for example. I guess more because that alone was enough to swamp read noise… not sure if any other benefits to that approach? Regards rob
Hi Rob,
I do broadband imaging with OSC, galaxy or otherwise, in 6+/7 skies. The n.1 thing is to get the proper image scale and thus sampling for you local seeing. Mine is between 2" and 3" depending on the season (better in the summer months and worse in winter). Thus my image scale with the 294MC is ~0.8"/px thus sampling my typical average FWHM well enough (between 3 and 4 pixels). I keep doing 3 min subs but could go down to 1 min in most part of the sky without any loss, especially toward the southern horizon which is badly affected by LP. I just cannot be bothered with the extra faff of handling large sets of subs. As others have postulated, you compensate the LP (natural and man-made) by increasing exposure time. Think 8x of a truly dark site (Bortle 1 & 2). And you'll need a lot anyway for most of the galactic faint halos. So, no less than 10 hours in my case, and upward to 3 times as much for some faint targets. My preference would be pure OSC as I cannot for the life of me go down the rabbit's hole of tackling severe LP with 4 filters (LRGB). With an OSC you just need a good LP filter and you're done (mostly…).
robonrome avatar
Thanks Andrea, that very helpful. Do you use an LP filter on your OSC even for galaxy imaging? Cheers rob
Optolong L-PRO is the way to go, IMO. All broadband imaging I carry out (well, with the 294MC anyway) are done with it in place.
Guillermo de Miranda avatar
I photograph from Bortle 8 skies and so far haven't used a filter to capture galaxies. I made this one from my very light polluted backyard earlier this year:
https://www.astrobin.com/x10xon/
DynamicBackgroundExtraction in Pixinsight is almost magical in its ability to remove thick gradients. Some of the dimmer galaxies are tougher to photograph, but it's certainly not impossible.
That said, I have recently purchased an L-Pro for some RGB nebula projects and I'm certainly going to try it on galaxies this winter.
Well Written Concise
robonrome avatar
Lovely triplet Cesar. Great detail regardless but all the more impressive from Bortle 8 and using a DSLR. Thanks for sharing!. Rob
Respectful Supportive
falke2000 avatar
I have a bortle 6 sky and I don't use any kind of light pollution filter when imaging galaxies. They are broadband targets, so you don't want to block any light coming from them. The most important thing is to have very long total integration times. With my ASI533MC and 6" f5 Newtonian I went with at least 10-15 hours for some of the brighter galaxies (See my gallery for examples). For fainter targets you would probably want even longer integration times.
robonrome avatar
Thanks Falke, some lovely Galaxy shots there with your asi533mc. Shows a lot can be done without filtering just longer integrations. Love the star colours as well.
Yusra Q. avatar
Hi Rob,
I am pretty sure you will do quite good. I did a few galaxies from a white zone with zwo asi 533 osc with uv-ir at f/4.7. The exposure varied from 20 to 45 secs. The final stack is very noisy (m31 came out yellow). Pixinsight dbe rescues my images. The stacking process takes very long because the light frames are usually 1000+. For this reason I dont drizzle as my system would take for ever to finish.
Second, i always feel galaxies are easier for me because i use game script in Pixinsight that allows me to generate masks mimicking the structure of the galaxy and I stretch only that area and keep the background noise down. I’ll be happy to share my m31 linear tif with you in case you want to post process it.
Tim Hawkes avatar
Hi Rob.  I faced the same problem.  Interested in galaxies but light polluted skies (Bortle 6) that puts the fainter stuff out of reach.
My solution  has been to take a slightly different tack and use lucky imaging to really dig into the detail of the cores of the brighter galaxies because that is something that you can do from a Bortle 6 site as well as from anywhere.  The seeing can be OK even while the transparency and light pollution may be poor.  Then on occasional trips to dark sky sites take possibly  lower resolution but far better SNR images to fill out the outer and fainter parts of galaxies
Equipment wise this has meant going for fast fairly long focus big reflectors (e,g, an F 4 Orion UK VX12 300mm and  F 5 SW PDS200) at an image scale of ~ 0.5 arcsec/ pixel  and also a CEM70 mount which can just about take these while remaining portable enough for field use.   These combinations provide reasonable SNR of the brighter core regions even at the short exposure times of less than a few seconds required for lucky imaging.   For lucky imaging  I have used a MONO camera (ASI294 MM) in unlocked pixel mode (2.315 uM pixels)  to j get luminance at a high sampling rate.  These core images  can sometimes be further enhanced  by deconvolution.  Then I have used an OSC (ASI294MC) to get the colour data at lower resolution (4.63 uM pixels) from the Bortle 6 - and if possible also from  darker sites.  It is then possible to combine everything together by using high dynamic range compostions of the overall luminance  and applying it to the colour data .
Taking this sort of approach  I have acquired quite detailed and extensive images of objects like M51  - and some interesting core detail on galaxies such as M63 and M94 even if the images do not show the full extent because all of the data were from Bortle 6.
I use a UV/IR cut filter but am not convinced that light pollution filters add anything.
One further fun thing to do from a Bortle 6 site though is also to take some HA data (for which light polution has little effect).  Like many others I add the HA data into the RGB data to emphasise the star -forming HA regions .  Particularly striking for galaxies like M51, M82 and M106 where the HA data really adds information - and indeed in the case of M106 even new galaxy 'arms'.  Another more ambitious one is to try using an SII filter to see HA in really distant galaxies.  A couple of galaxies in the COMA cluster are far enough away (350Mly) that the HA band is red shifted by ~ 16 nm .
So while living at a dark sky site would be ideal – overall still plenty of scope to do galaxy  imaging from more light polluted locations imo.
Tim
[deleted]
Yes the L-Pro filter is the way to go for imaging galaxies under light polluted skies.  I do 5min subs at 300 Gain, or when I was using my Canon it was ISO800, from my Bore 8 backyard.  I live about an hour and a half away from a Bortle 4 dark site so whenever I want to capture good signal for galaxies I go there.  Obviously I don't need a filter at a dark site.  As others have said here, when using a filter under light polluted skies you'll need more capture time.
robonrome avatar
Thanks Yusra, Tim, and gfunk for you helpful replies. All very much appreciated.
and Tim, wow, there is gold in what you say and much food for thought.  Had never occurred to me for example how redshifting of distant galaxies might play into my poor filter choice selections. I have the asi294mm so could try bin1 lucky imaging… do you stack and process differently for this (more like in planetary imaging?)… otherwise can imagine my machine wouldn't cope with the sheer scale of data.
I'll also need to look at how within my processing software one can work the luminance to this extent and then apply colour. I own pixinsight but after several failed attempts (its like its from mars and im from venus or vice versa) continue to use APP, Startools, and PS… and all probably too superficially (eg I push buttons and pull levers til I see something I like rather than understanding why).  Sounds like whatever software I use I'll need to delve a bit deeper.
starfield avatar
Hi Rob,   I shoot from Bortle 7 and have found two keys that helped.   1st was shooting 60 sec subs.   I used Sharpcap's "Brain" to come up with this and that works well for the 294mm (haven't shot many galaxies with the 2600mm yet).     I also noticed that I was able to get better results shooting mono.   Managing the gradients just seemed a bit easier.   I also found that the NSG script in PI helped some too as there a big difference in my gradients as I get closer to the horizon.
As others have said, also just going for more integration time definitely helps.
Helpful Concise Supportive
Torben van Hees avatar
I‘m shooting from Bortle 6. I tried the Astronomik CLS for this and in my light pollution it does not help with galaxy images but just reduces the object signal and skews colors.
If you look at my images, I think you‘ll get a good idea how much integration time is needed. At Bortle 7, you need to multiply by 1.2-1.5x, approx. For something faint things like halos, low surface brightness galaxies or IFN, upwards of 20h is needed.
I find the biggest challenge to be large-scale chromatic noise. It‘s devilishly difficult to control when it overlays the galaxy. For the small-scale noise there are good tools, but against the large scale residues, the only thing that helps is to gather more light to average it out: Long integrations and high etendue. I feel my 10“ RC is still too small. This also limits the efficiency of LRGB because I can devote a maximum of 20-30% of the time to L and still control color noise.
What you won‘t be fighting as much as in shorter FLs are the gradients: In the smaller FOV, they tend to be rather linear, especially if you shoot mono. I‘m experimenting with using wide-FOV shots for the gradient removal for the small-FOV ones. I’m not decided yet if it is worth the additional overhead. The new PixInsight LN and the PSG script both help a lot to reduce them, too.
Helpful Insightful Engaging
robonrome avatar
thanks Starfield, I have sharpcap but haven't much used it's full capabilities really just for polar alignment. I must see what it has to say optimum exposure length.
robonrome avatar
thanks Torben for your insights. Love your gallery. That's the kind of thing I'm after and shows what is possible. Not sure my skill level is to the point I could discriminate large scale chromatic noise over small scale. A lot to learn. No doubt I am still bludgeoning issues with blunt tools that probably require a much more finessed approach. Your last point on FL helping to manage gradients makes intuitive sense and was one gain I could see from going longer.
Tim Hawkes avatar
and Tim, wow, there is gold in what you say and much food for thought.  Had never occurred to me for example how redshifting of distant galaxies might play into my poor filter choice selections. I have the asi294mm so could try bin1 lucky imaging... do you stack and process differently for this (more like in planetary imaging?)... otherwise can imagine my machine wouldn't cope with the sheer scale of data.
I'll also need to look at how within my processing software one can work the luminance to this extent and then apply colour. I own pixinsight but after several failed attempts (its like its from mars and im from venus or vice versa) continue to use APP, Startools, and PS... and all probably too superficially (eg I push buttons and pull levers til I see something I like rather than understanding why).  Sounds like whatever software I use I'll need to delve a bit deeper.
Hi  Rob,
If you have a scope > 8 ",  PixInsight , and an ASI 1294MM then you have everything you need right there to get some good lucky imaging of galaxy cores quite easily.  PixInsight has amazing capability - a steep learning curve but it really is worth persevering with.
As a starting place try maybe say 1000 x 3s subs at gain 285 unbinned at 2.315uM of something like M57 or M51 when it comes around again.  If you don't fancy handling all of those 1000 subs then just use a program like Sharpcap to a) select good subs (FWHM and brightness filters ) and then just let sharpcap apply the correct darks, flats do cosmetics and autostack it for you.  Take the saved .FIT autostack into PI  -   and process as normal (background removal, noise removal etc) through to histogram transformation to give you a stretched mono image.  With any luck this should be sharp. Even in the UK I have been getting down to FWHM 1.5-1.8 for the initial linear (unstretched) stack.   Then get a normal colour image as ypou normally would- at lower resolution (4.63 uM pixels) -  with longer subs and lower gain, process and stretch in the usual way.   So now you have two stretched images, one mono (luminance) and the other RGB  (in my case obtained using an OSC camera).  Then align the lower resolution colour image to the sharper mono image using the Dynamic Alignment tool in PI.  Next use the LRGB colour spaces tool with just the L box and chrominance boxes ticked  - with the L menu selecting your mono image - and select the colour image for processing with the triangle icon.  You should then see the colour image sharpen up as it takes on the mono luminance.  Then curves  etc etc for final processing.
Loads more than that of course -  especially deconvolution which is very powerful and learning to combine  luminance images  into a single high dynamic range luminance image.  But just trying something like the above would get you started on the tools for transferring luminance  - and then the rest falls into place.
Tim
robonrome avatar
Thanks so much Tim for your excellent information. Only thing I'm lacking then is the 8inch scope ;-)… but then getting a bigger scope is easy… learning PI, well, Ive got degrees in electrical engineering, 40 years in Telecoms networks, and a PhD in archaeological science (nuclear sourcing analysis), but ive never, ever, come across a piece of software more baffling and unintutive to me than PI … where even the simplest of tasks such as cropping becomes a challenge… While I'm not familiar with the specific tools/modules in PI the way you explain the process makes sense to me. Big sigh… I guess I'm going to have to make attempt 4 at pixinsight and grit my teeth. I suspect the tools I have can do the job, but seems as most use PI if I want to shortcut and learn from others it may have to be the way. Had been thinking I could start by still doing my stacks to unstretched channels in APP  and input those to PI and focus first on learning PI as a processing tool rather than stacking as well. Anyway, thanks again.
TS Photon 10" f/5 (or similar telescopes) experiences wanted
Hi folks, I am quite new to (real) astro photography. About a year ago, I started with a Bresser Exos-1 mount and my DSLR. I was quite happy with my results and soon wanted a real mans telescope. Last autumn I bought an EQ6-R Pro mount and was really...
Author new to serious astrophotography; equipment recommendations for imaging useful.
Mar 16, 2021
4 Cameras ... opinions?!!!
Hi all, It has been really long time since i posted here or even reading, got busy and carried out in life and astro became like forgotten passion for a while now. Anyway, i am trying to get gear as possible to finish my setup i need, and the long i ...
Discusses camera options; author has experience with multiple cameras.
Jan 31, 2024
Large telescopes and seeing - what does make sense?
Hi out there, an often asked question brings up a thought I have for a long time and I'm not sure if I answered it to myself correctly. So I'd like to ask for some explanations to help me understand this better. There is always this recommend...
Explores telescope selection and performance; relevant to author's scope expertise.
Feb 4, 2024
OSC Cameras for Deep Sky imaging with Edge 8 HD...what are you all using?
Hey folks, I'm just in the midst of building out an Edge 8 HD system and am looking for recommendations for an OSC camera for some deep sky astrophotography? I have the 0.7x Reducer too, so will be likely using that for most of my projects…...
OSC camera recommendations; author uses mono/LRGB and may consider alternatives.
Feb 16, 2024
L-xtreme filter
Hello all my fellow L-xtreme filter users. I purchased the filter about a month ago and have posted a few images on this forum. My latest project was the Spaghetti Nebula ( Sh2-240). I have found that the filter performs really well with long exposur...
Bortle 7 imaging techniques; directly relevant to light pollution challenges.
Dec 8, 2020
