Powering a Mele Quieter 2 with a Pegasus Powerbox
4 replies463 views
Anderl avatar
Hey,
i am just noticed that I can't run my mele quieter 2 by using the usb hub on a Pegasus Astro powerbox advance.
someone on astrobin recommended to use this adapter https://www.amazon.com/gp/product/B07XZ7Q2N7/?pldnSite=1&th=1
but I wonder, is this really going to work? there is a note that this adapter isn't able to get used with 12v devices.
are there any other (better) solutions to power my mele through my powerbox?
thx and cs
Andi
Eric R avatar
I have the Powerbox Micro and use that adapter for the quieter3 and it works fine.
Vasile Unguru avatar
Hi Andi,
I used this cable https://www.amazon.de/-/en/gp/product/B085M3F4XQ/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1. Plug it in 12V output of Pegasus and the other end (USB C) in the Melee. It has to be powered by 12v source, not usb hub.
I hope you will solve it.
Vasile
Neil Springate avatar
I am surprised these work. I'm trying to find a solution for this and what has been described is not suitable for 12 volts, they are 5 volts only.
Aris Pope avatar
Hey,
thx and cs
Andi
https://a.co/d/5RwnLEe
That all you need I plugged mine into one of my 12v ports on Pegasus and have been powering my Mele flawlessly
Remote Imaging - which mini-pc
Hi everyone. I apologize if the topic has already been discussed in the past, but I haven't found any recent posts on it and given that mini-PCs evolve quickly I think it's not wrong to open a new post. I'm thinking of buying a new PC for...
Discusses mini-PC power solutions for remote astronomy imaging setups.
Jun 24, 2024
RaspberryPi for imaging, USE A BATTERY!
Hi, I don't have a question but just some info that might be interesting for folks that use the RaspberryPi (RPi) to capture images. Don't know if I'm telling common wisdom here but here it is: I'm using a RPi4 to capture images with ...
Relevant - discusses powering devices via USB hub, similar power supply considerations.
Mar 12, 2021
