Emmanuel Valin avatar
Hi all,
How to achieve pinpoint stars in my images?
I have the following in mind, am I missing anything?
- Good seeing conditions
- DSO high in sky
- Good optics
- Perfect tracking / guiding / polar alignment / scope balance
- Perfect focus
- Flat field & in same plane as camera sensor
- Short enough exposures to avoid star bloating
- Good quality filters
- Good star reduction in processing stage
Feel free to share your tricks!
Clear skies.
Helpful Concise Engaging
V avatar
Hi Emmanuel, after seeing your images (which are pretty nice!), I can tell that you've stretched the entire histogram on some of your images instead of the middle centered portion of it- this causes the transition from the stars core to the darkness of space to be sudden and makes stars look like they were put in ontop of the image, it also bloats them out past the normal transition line. If you use only the black point and grey point sliders, the stars cores stay sharp, and the transition is very nice.
I image at F/7 and 1422mm focal length, so I have to be very careful as to not explode my stars, but what I do is I never stretch the entire histogram of an image, using only the black point and the grey point sliders in GIMP (what I use for processing), and never touching the White point slider unless absolutely necessary. Additionally, sharpening images can reduce star size, but not that much.
Tim Hawkes avatar
Hi Emmanuel,
I would break down  your  heading "Perfect tracking / guiding"   a little further.
It is possible to have perfect optics, conditions, no wind etc as well as near perfect guiding, equal in RA and DEC  according to PHD2 which - typically -  is sampling  at say 2.5s intervals BUT  still end up with elliptical stars.
That is because some mounts  suffer high frequency (too fast for PHD2 to track) micro-excursions as they track in RA which occur on the sub-second timescale.  For example I have seen short sharp 2 arcsec back and forth movements in RA occuring about once a second.   This creates elliptical-looking  stars that are fatter along the RA axis .
So to your list I would add  " a good quality mount"
Tim
Helpful Insightful Engaging
V avatar
My CGEM II has this- but at a bad level, and it forces me to use 0.5s exposures to offset this issue. Thankfully, my guidecam is at 2"/px so I dont get any seeing issues, stars appear as pretty much a solid cuboid-ball the entire time. Gets me 0.8" guiding on a bad self-tuned CGEM II though, so I can't complain.
kuechlew avatar
Congratulations to your very nice collection of images - way better than what I'm able to create so far. A tip from beginner to beginner: Don't obsess about details like pinpoint stars, the stars in your images are good enough. It's ok to try to improve as much as possible, but it's easy to loose the fun of the hobby if you're too critical about your results and focus too much on little details.
Clear skies
Wolfgang
Respectful Concise Supportive
17 things I did during the last year to greatly improve my astrophotography
17 things that I did in the last year that improved my astrophotography. Hi, I am an amateur astrophotographer. I have spent about 10 years doddling with it, even taking a 3-year break during the pandemic due to work commitments. I came back to it in...
Shares practical improvements for astrophotography quality and star sharpness.
May 22, 2024
The need for REAL signal - Thoughts on true image quality
Having just been getting back into the astrophotography fray lately, after having been largely out of the game for a few years, I thought I'd start a discussion on the need for real signal. I kind of landed here, in 2024, right in the middle of t...
Discusses signal quality and image quality in astrophotography.
Mar 8, 2024
Newt Astigmatism: tilt or secondary mirror?
Hello, I'm struggling to get good star shapes across images from my ONTC 10" F4, specifically around the corners. I tried everything and can't seem to locate/confirm the source of my problems. Some information about the setup: General Se...
Addresses optical issues affecting star shape and sharpness.
May 24, 2024
