Light Leak in ZWO 183GT?
8 replies267 views
schmaks avatar
The first light with my 183GT revealed there may be a light leak
Here’s a shot of one of my M51 subs (stretched):
Here’s a shot of one of my dark frames:
Has anyone experienced this? What can/ should I do?
Benny Colyn avatar
It's amp glow, which is normal for this sensor. Calibrates right out, don't worry.
wsg avatar
It is not a light leak, it is amp glow.  You can read all about what it is and how to deal with it here.
https://astronomy-imaging-camera.com/tutorials/what-is-amp-glow.html
Well written
schmaks avatar
Benny Colyn:
So this is a usable sub and I should continue as planned?
Andy Wray avatar
Benny Colyn:
Yes, definitely
Benny Colyn avatar
Benny Colyn:
Honestly, I'd check my focus. Looks a little bit off. But the sensor is doing its job, no light leak.
schmaks avatar
Benny Colyn:
Benny Colyn:
Yes, I am still waiting on the EAF to arrive.
schmaks avatar
Andy Wray:
Benny Colyn:
Yes, definitely
Phew!
Daniel DeSclafani avatar
Did you figure this out? I used to use a 183 plenty. That on the right is amp glow. However, the bottom left corner looks as if it could be a light leak. I don’t ever remember having another glow there.
Newton Flat Problem (Ring pattern) Light pollution a cause?
Hello guys, I've already read a lot of forum post about this topic. Usually the problem apears to be reflections inside the tube, light leaks, sometimes the corrector sticking inside of the tube or a GPU causing wierd stuff. Some people are doing...
Light leaks cause reflections inside tube; directly addresses your problem.
Mar 13, 2024
Reason for those linear image artifacts
Hi there, during the last nights, I collected some data of M51. Today, I stacked the images and in the master frames, i realized a linear halo through all of them. I could not detect those issues in the subs, but I guess they are there and just can&#...
Linear artifacts in M51 stacked images; similar issue to your light leak.
May 15, 2024
