lens cleaning
2 replies164 views
Uwe Deutermann avatar
Hi Everybody!
Does anybody have a suggestion on how to clean lenses of a refractor without leaving permanent damage? I scoped a lot last year and see that the front lens collected a bunch of pollen (and it is sticky!), and I definitely would like to get rid of those spots.
Uwe
Rob Johnson avatar
Hi Uwe,
I've only cleaned small apertures but find that a tiny amount of soft soap - handwash type - in deionised water works well.
Use very soft disposable tissues (the type without impregnated additives) and gently wipe the lens. Repeat several times until you remove the dirt then finish with some plain water and dry. Its hard to remove the final streaks but can be done.
Hope this helps,
Rob
Well written Helpful
Keith F avatar
Hello Uwe,
This comes straight from Astro-Physics and the only way I would ever clean a lens in need.
http://www.astro-physics.com/tech_support/refractors/Lens_Cleaning_formula.pdf
Keith
C8 plus an Orion 80mm ED refractor on a CGX-L
In September I bought a C14 and then a CGX-L mount, because the C14 was a little bit hefty for my CGX mount. I tried some imaging with the C14/CGX-L combination, and it worked pretty well until anything more intense than a gentle breeze came along. T...
Not relevant - discusses telescope mounts and imaging, not lens cleaning.
Mar 17, 2020
Help Sony a7III Interval shooting mode
Hi everyone ! Last week i've been imaging NGC6960 and had a weird problem with the internal interval shooting mode of my a7III. Every now and then (sometimes after less than 5 pictures, sometimes never without changing any settings) the camera st...
Not relevant - discusses camera interval shooting mode, not lens cleaning.
Apr 26, 2020
