Hi NeedsMoreCoffee. I just spoke to the guys at Sky-Watcher. I purchased an Esprit 100 today and wanted to verify the spacing for my DSLR and CCD cameras. They told me that the manuals at their website are correct for the OTA's they are currently shipping. Here is the link for the Esprit 80 (
http://skywatcherusa.com/downloads/manuals/S11400_Esprit80EDT.pdf). The relevant information is on p.8. I'm guessing that since you are asking about spacing that you are not the first owner of the scope and so did not receive a manual. So, there are at least two possible spacings. For new scopes it is 66mm. For older scopes, it is 61mm, as noted by Boutros (here is a link to the older manual,
https://www.manualslib.com/products/Sky-Watcher-Esprit-100-Ed-Super-Apo-3386196.html). In both cases Sky-Watcher shipped a spacer (step down from 66mm threads of the flattener to 48mm threads of the DSLR T-ring) already assembled with the flattener. For the 66mm version the spacer is 11mm. For the 61mm version the spacer is 6mm. So, to find out what scope you have check the spacer on the flattener. If it is 11mm the optimal spacing from the flattener to the sensor is 66mm. If it is 6mm the optimal spacing is 61mm.
Good luck, NeedsMoreCoffee. Looking forward to your images.
