What would cause flats to not correct properly?
9 replies544 views
Rouz Astro avatar
  • Pix Insight WBPP
  • QHY600m – CDK14 + Reducer
  • Filters are 50mm with filter masks, the Astonomiks even have a built-in mask (plus additional plastic masks).
  • Chroma filters have the same pattern
  • Spike-a-flat panel
  • There are no light leaks  -   daytime darks = nighttime darks
  • Darks – Flats – Darkflats all matching gain, offset
  • Focuser and rotator at exact same position as lights
 Any ideas would be great.
Pablo Gazmuri avatar
Things I've learned:
1. Make sure your offset is high enough. The left side of your histogram should be zeroed out.
2. Make sure you are taking flats at the same focus point where stars are most in focus. Even if you haven't touched the focuser, if the temperature has changed, you may be out of focus.
3. Make sure your average ADU reading is high enough on your flats. If you have a non-linear sensor then a lower average ADU will likely work better.
4. Take separate flats for each filter, as they alter the light path.
Helpful Insightful Concise
Spike-a-flat panel
That's your answer
Rouz Astro avatar
Spike-a-flat panel
That's your answer
You mean its not even?
I tried sky flats, was similar.
My old smaller Spike a flat and smaller cdk and reducer calibrated perfectly.
Rouz Astro avatar
Pablo Gazmuri:
Thanks Pablo,
Offsets seems ok, lowest pixel value is 231ADU
Focus point is accurate, I use offsets per filter, very accurate focuser, carbon truss, fused silica optics. I doubt its focus shift.
Tried flats from 30% to 80%, didnt solve the problem
Each filters has its own flats, its own darkflat and filter offset.
Im suspecting internal reflections maybe?
How do you take them? And how do you reduce them (this in general, not specific to what type of flats you're having). Open truss scopes are notoriously finicky in these matters and sky or dome flats are the (professional) way to go.
kuechlew avatar
Does it look the same for all your filters?
Trying to compile a list of "what are all the things that changed in my setup since I had it working last time" is a good start to nail down the potential issues.
Looking at the image I can only come up with the question: What in your setup is different in the lower right corner compared to the other corners?
Admittedly the upper right corner is not perfect either but maybe address the main issue first.
If this was my image I would bet on the OAG obstructing the edge of my sensor. I would rule this out for an experienced user though …
Good luck and clear skies
Wolfgang
Rouz Astro avatar
I may have just found something.I went to the dome, the telescope and baffle had a dark cover on. With a bright LED flash light I checked each one of the 15 connections and taped them all up. One connection near the camera had a light leak, that could be it. With the flash light it was a severe light streak on the image.The flat panel may have illuminated that side externally, causing that issue. Its clear tonight so Ill try lights and flats from scratch. Will report.
Jim Matzger avatar
Try the Sequence Generator flats calibration wizard to check the proper exposure time.  It worked for me.
Rouz Astro avatar
Jim Matzger:
Thanks, Im using NINA exposure calculators.
Ordered some flat black paint and will paint the entire imaging train.
Blue flats no good; all others ok ??
Good Day All - I have a strange problem with flats: I collect L, R, G, B, S, H, O flats all during the same session, all at about 30K, using the exact same illumination flat panel with no changes between flats acquisition (other than time duration in...
Blue flats issue; author troubleshooting filter-specific flat calibration problems.
Dec 15, 2023
"L" flats problem..
Hello All, My L flats at 3910 mm never seem to apply properly in WBPP; or at least not as well as the RGB flats. SHO always seem to work well. All else being the same. Values are consistent, calibration method in WBPP is consistent (with the other fi...
L flats application in WBPP; directly addresses narrow-band flat calibration issues.
Mar 15, 2024
EdgeHD 8 - Flat problem on Green and O3
Hi! I'm having some trouble getting my green and O3 filters to calibrate properly. The image attached is an example of what's happening. The image on the left is without flats, the one on the right used flats. Both images were run through Gra...
Green and O3 filter calibration; similar narrow-band filter flat problems.
Nov 10, 2023
Newton Flat Problem (Ring pattern) Light pollution a cause?
Hello guys, I've already read a lot of forum post about this topic. Usually the problem apears to be reflections inside the tube, light leaks, sometimes the corrector sticking inside of the tube or a GPU causing wierd stuff. Some people are doing...
Newton flat ring patterns; addresses flat calibration issues with filters.
Mar 13, 2024
Running list of known CDK 14 issues and fixes
I thought I'd fork off the discussion from the other thread and gather a list of things that a new or prospective CDK 14 owner should be aware of. Although it's disappointing that Planewave aren't shipping better OTAs or fixing known issu...
CDK 14 known issues; author uses CDK14 telescope system.
Apr 21, 2024
