Yes i already have thought about a tracker, but i wanted to start with something easy and fast to use and see if i'm really interested in deepsky photos.I already needed a good fast lens in that range (the only close lens i have now is an old nikkor 60mm 2.8 ) for other reasons like landscape etc so ill start making some tries with that, then i will considerthe tracker option
Marc Ricard:
increasing the ISO will reduce the available dynamic range.
Guillermo Spiers:
but remember that you will have less dinamic range, and star colors may blow out.
Do you mean that by overexposing you get too much light and colors?
No. What they are saying, very correctly, is that as you increase your ISO, the dynamic range of your image will shrink. Plug your camera into this page (
http://www.photonstophotos.net/Charts/PDR.htm) and you will see the effect. I am using a Sony a7RIII ATM. AT base ISO it's dynamic range is just shy of 12 stops, at ISO1600 8 stops and at ISO3200 (a not too uncommon ISO in AP) it is way down to 6.3 stops. 2^6.3 is just about 79. So, my image will only discriminate between 79 brightness levels. That is another argument for using a tracker. Given the ability to use longer exposures (minutes, not seconds) you can use significantly lower ISOs. Let say with your sensor/lens you get round stars at 20 seconds and ISO 3200. If you can increase your exposure time to 160 seconds, then you have gained 3 powers of two which you can spend on your choice of smaller aperture and lower ISO. So, you could shoot at ISO 400 at the same aperture. That will greatly reduce your noise and increase your dynamic range -- in my case to 9.7 stops of DR v.s. 6.3 at ISO3200
