Autoguiding Cam ASI178MC or 120MM-S
4 replies214 views
Michael Timm avatar
Hi fellow APs,
until now i used a ASI120MM-S (mono) as an autoguider and the ASI178MC (color) for imaging. Due to an update i will use a new 294MC Pro as imaging camera in the future. So now i have two cams available for autoguiding. Which one should i use? I am using a 8" RC (203/1624) with an OAG, see this image: OAG.
From the manufacturers website i know that the 178 (178 specs) is less noisy compared to the 120 (120 specs). But i believe the 120 to be more sensitive due to its monochrome sensor. Am i right or did i misunderstood the diagrams? Which decision should i make? Are there any obvious advantages / disadvantages i do not see?
Any advice appreciated, thanks and greetings,
Michael
GregGurdak avatar
Hi, in my opinion avoid using  colour camera for guiding because stars looks bloated,  bigger about 20% than in mono camera on your PHD screen, especially when you’re shooting with long focal length telescope and  you need more precise guiding than short FL telescopes
Michael Timm avatar
Thank you, Greg. You made a point here for the ASI120. I will include your suggestion in my reflections.
Tele avatar
120mm-c is a very good auto-guider. Transfers data very fast on a short usb3 cable, small pixels, mono, very sensitive, just load black frame for noise compensation.
Michael Timm avatar
Yes, i am using the 120MM-S mono and it works great. Thanks again, all!
ZWO ASI178MC for DSOs?
Hello out there, Capturing Hubble images is not the intention, so I am wondering whether the ZWO ASI178MC would be good enough for DSO imaging on a 450mm refractor or 750mm newtonian. Not planning to fumble with a filter wheel. When using a barlow fo...
Discusses ZWO ASI178MC performance for DSO imaging, directly relevant to autoguider selection.
Aug 16, 2019
Focal Reducer for RC 8"
Hi fellow RC-Users, i own a 8" RC and want to buy a focal reducer. This is my current setup: Setup with OAG Please notice the OAG, which works fine :-) The idea is to buy this FR: Astro Physics Reducer The setup would be like this: Scope -> F...
Addresses autoguiding camera selection and light sensitivity for guide star detection.
Feb 27, 2018
