I am replying to this post, over a year later, just to inform others who may be using this as a resource.I don't think the star flaring is from pinching or tabs in the objective cell.
I have the same phenomenon on my GT-71, complained to William Optics who took the lens cell back, "fixed it", sent it back, with zero change.
So I launched a series of tests, and now, after 7 telescopes, have concluded this is "normal" (and what WO told me in the very beginning).
It seems all telescopes have flaring of brighter stars to some degree. I even tested my homemade Newtonian, where I glued the primary and secondary to avoid diffraction from mirror clips, and it too had flaring (though there was still some glass in there, due to the corrector, which cannot be easily removed).
This is a photo-summary of the 7 telescopes tested so far, as well as the GT-71 stopped down in the front to 60mm:
https://www.flickr.com/photos/125134422@N06/albums/72177720308616569My conclusion is that star flaring is not that unusual, and is not a "defect".
Yes, some scopes have more flaring than others, but none are entirely free from it.
I don't think it is in the camera, as each scope has its own characteristic "structure" to the flaring.
It is interesting how the telescope with Fluorite has a much finer flaring structure than the others. Fluorite has very low dispersion (Abbe number=94.99).
I also find it interesting that my much older William Optics 71 Star II Petzval has a very different flare structure than the new RedCat 71 Petzval.
Both have identical specifications and use 4 elements, in the same or similar configuration.
I expected those two to be the most alike, but that is not what the test results show.
I am not done with the testing, but an early conclusion is that the flaring is either from within the glass, or the surface finish, or even the coatings (the latter two might explain the Newtonian flaring).
But I do not think it is from physical objects within the OTA or pinching (testing was done at "comfortable" temperatures, ~ 10 Celsius)
Steve
