For suitable trackers I always point to iOptron Skyguider Pro or Skywatcher StarAdventurer. For the latter you currently can buy the 2i but a more expensive and potentially more capable GTI model is about to get released. For videos on how to use the trackers look for (1) The Narrowband Channel - YouTube or (1) Nebula Photos - YouTube or (1) AstroBackyard - YouTube
Considering the lens the main question in my eyes is whether you buy it primarily for astro photography or primarily for daytime photography. In the first case consider a small scope instead of a lens. LBN 515, LBN 535, LBN 558 ( spacetimepictures ) - AstroBin is a nice example what can be achieved with a tracker + a small refractor + a Sony camera (+ software + a lot of practice to use it properly ...). Alternativly the Samyang 135mm is a nice step up from your current kit, e.g. ngc1499/m45 wide field ( Nenad Vasilijevic ) - AstroBin
Based on your budget you may choose a more expensive Sony or Sigma prime lens which may be more suitable when used for daytime photography too.
Good luck and clear skies
Wolfgang
*** Appreciate your detailed feedback, most definitely it would be the latter, where I can have a lens that can do both daytime and Astro photography, from the suggesting I am getting I believe the 600mm might be a hard sell for something like the star tracker 2i or even GTi.
I may consider either the suggesting Samyang 135 or look into the Sony 135 as well, on the contrary I can also look at 70-200 f2.8 or a 100-400 f4.5-5.6 I a want a more suitable weight/focal length ratio for a 5-600$ star tracker, what do you reckon?***
If you want to use your lens for both daytime and nighttime photography you have to decide on your best compromise between both. For daytime both a 70-200 or a 100-400 are a good fit to your existing 28-70. If you pursue mainly daytime photography I would go for one of those two - depending on what's more important to you f2.8 or the additional focal length.
As Andrea pointed out correctly, for astro photography prime lenses are to be preferred. Even good expensive zooms for daytime photography can perform surprisingly bad when pointed at stars, e.g. my Canon 70-200mm f2.8 L IS is a complete lemon (to my taste).
The trackers won't have issues with the weight of a 100-400 or even a 200-600. But tracking accuracy can become an issue at the long end beyond 300mm.
Since the Samyang is fairly low cost you may just buy it in addition to a 70-200 or 100-400 ...
Clear skies
Wolfgang
