Esprit 120 or Skywatcher Quattro 200p
7 replies713 views
Codey avatar
Hi all,
anyone with experience with the Quattro 200p?
Im considering this with a few extras EAF, OAG, Coma corrector.  I’m coming from the RedCat51
also considering the Esprit120, but happy to save the extra $3300 😂
cheers l
Marc avatar
I use a system that was built from a Quattro as a donor. The original Quattro, as far as I know, is a pretty reasonably performing scope. Obviously, at this price point, you will have to live with some "limitations". The optics in itself are pretty good; the mechanics, I assume, are probably alright but not exactly "premium". My biggest concern would be the focuser. At F4, you really cannot have any flex or tilt in your imaging train - which requires not only perfect collimation, but also mechanically stiff components. The stock focuser might be alright, haven't used it. But I have used a similarly priced Newton way back when and that one had a terrible focuser smile
Also, if you come from a flatfield APO, the process of taming an F4 mirror system will probably be a bit of a challenge. It's doable, obviously, but it creates some overhead you are not yet used to.
Regarding the Esprit 120 - I also happen to own an Esprit 100, which I can warmly recommend. I assume the 120 is no different - a well-performing, low-maintenance scope. The speed is an issue of course, but F5.5 is not too bad, really (basically, you need to collect twice as much data compared to F4). But it really is very much plug-and-play, most of the time. I have not yet lost any time imaging due to scope-issues, whereas the Newton cost me many a night due to collimation issues etc. I am however very, very picky about this sort of thing. Others will happily live with slightly elongated stars in one corner.
Either scope will require a fairly robust mount - EQ6-R or above, I would say - if you plan on doing long-exposure astrophotography.
Good luck with your choice!
/Marc
Codey avatar
Marc:
/Marc
Thanks for the in-depth reply Marc, yeah I agreed the esprit being pretty much plug and play it better be for that price 😂 and coming from the RedCat51 should be a easier learning curve. I am using the EQ6-R so thats sorted.
Cheers.
Mossyback avatar
I have the Esprit 120 and can’t say enough great things about it. From the moment I put it on my MtY mount it’s been a joy to work with. The only change I would make would be buying the 150mm but my pockets aren’t that deep! ;-)
Hank
Well written Engaging
Andy Wray avatar
For the money I would go with the Quatro pro with  coma corrector and an autofocusser.  I see so many people on here spending thousands on the OTA when actually they should be spending their money on the mount.
Concise
jewzaam avatar
+1 for the Esprit 120.  I run mine on an EQ6-R Pro.  Only problem is the length of the scope.  You'll want a tri-pier if you don't have it mounted on a pier.  I don't yet and it means I don't image at some declinations for fear of hitting the tripod legs.
Eddie Bagwell avatar
I would go for the Esprit 120 also and get the Sky Watcher Pier Extension for your EQ6R. I did a review on the installation of the extension on Cloudy Nights. Here is the link:
https://www.cloudynights.com/topic/769772-sky-watcher-eq6r-pier-extension/
Codey avatar
I've come across the Orion EON 115, any thoughts on this?
Remote hosting considerations
Hi All It becomes gradually more and more frustrating that I have all this great equipment - but NO clear skies So I am slowly starting to consider remote hosting options and are curious to get some feedback on a few thoughts. Telescope focal length?...
Remote hosting could address clear skies issue affecting equipment use.
Mar 2, 2024
Coma corrector suggestions for SkyWatcher 150PDS
Hello everyone! I was wondering if you have any suggestions for a coma corrector to pair with this telescope (SkyWatcher 150 pds)? I have the Baader mpcc iii which i’m not happy with as it is quite susceptible to tilt, Although, it does a great job i...
Coma corrector recommendations directly relevant to author's planned purchase.
Apr 2, 2024
