DSS Problem - Only one frame is stacked
14 replies478 views
MarZ avatar
Hi everyone!
I have a little problem with DSS. Yesterday i made 8 light frames from M13. 2s exposure,ISO 3200, no tracking, 700mm focal length. But DSS olny stack one frame out of 8.
Can someone tell me, where is the problem?
Single frame(very noisy, becouse i needed to convert ti jpg from CR2) :
Carastro avatar
Common problem with DSS.  It is likely it will only stack 1 frame because it is not seeing enough stars to register the images.
You can try lowering your star threshold in Register checked pictures/advance tab and see what happens.  It is likely since your exposures are so short it is not showing up the stars enough for DSS to recognise them.
Failing that you might need to stretch the individual exposures to make the stars more visible before trying to stack them.  This is not ideal or the right way to do it, but it might help to diagnose your problem.
Carole
MarZ avatar
I tried it, but didn't helped.
Can it be the problem, that the picture is too noisy?
But i don't know why.. only ISO 3200, with 2s exp…
Ron avatar
This may not help, but don't convert to JPG format.  If you have to convert the CR2 files, convert them to 16-bit TIF format.  If nothing else, yuo'll be in better shape to do a prestretch as Carole suggests.
Alternatively, you can download the new 64-bit (there is also a new 32-bit) version of DSS.  I couldn't stack CR2 files with the older version, but now I can with the 64-bit version.
Ron
MarZ avatar
Okay, I will try, and thanks!
But, can it be a problem, that i dont use tracking, so the target is moving, and have different position on every frame?
Scott Butler avatar
Which version of DSS are you using? I can stack CR2 files in my 3.3.4 version…
As already stated, don't make them into jpeg…..
Scott
Ron avatar
MarZ, I've heard that DSS can have trouble identifying stars if they are not round enough.  So that might be what is happening, especially if you are not guiding.
Scott, My understanding is that as new models of cameras are sold, a support file needs updating.  When folks have had trouble stacking, once they updated the software, the problem went away.  Recently, the support for new cameras was dropped, but with the new versions of DSS, a new support file is being used and new cameras are again supported.  I recently obtained a new Canon whose image files were not supported by DSS.  Once I downloaded the new version, the images opened.
Ron
Carastro avatar
Okay, I will try, and thanks!But, can it be a problem, that i dont use tracking, so the target is moving, and have different position on every frame?
Provided the stars are not too mis-shapen that is what stacking software will do, move the frames so they sit on top of each other in the right position.
Carole
quinti avatar
hi there,
you may use fitswork instead. Its not as easy as dss but it can align your pics if you can see 2 stars.
Michael Timm avatar
Another option is to use SIRIL for stacking. It is capable of stacking with several methods and does a god job there. Due to its complexity i only use it when DSS has a problem with stacking.
Carastro avatar
Just looked back to your original post, you say you were doing 2s images.  Presume this is 2secs.  I think it could just be that the exposures are too short for the stars to show up very much.
Carole
Concise
Jeffbax Velocicaptor avatar
Hello. The frames must have the same dimensions to stack. Check this point.
Regards.
JF
Michael Timm avatar
Carastro:
Whenever i am doing short exposures i have the same problem with DSS-stacking like MarZ. Then SIRIL will do the job.
zs1chq1 avatar
I think you can try SIRIL! smile
Deep Sky Stacker removing too much color from my Orion stack
Hello everyone, I am having a problem with DSS. Single 120" Image: https://www.dropbox.com/s/4z58cbukm9c8ag8/IMG_9866.CR2?dl=0 Stacked and Calibrated (dozens of Darks, Flats, and Bias) using 3 hours of exposure (Cropped and Binned in Star Tools)...
DSS stacking issues with color processing and frame rejection problems.
Jan 7, 2017
Stacking in Photoshop
Does anyone use Photoshop to stack your light frames? I usually just use DSS but have been having problems with it lately. For one, it doesn't like the RAW files from my SONY DSLR and I have to convert those to another format before it will stack...
Alternative stacking software when DSS encounters frame recognition difficulties.
Nov 26, 2017
