Qhy128c vs Atik 11000 or 16200
3 replies226 views
PascalB avatar
Hello i’ve got a celestron c8 edge hd and an altair 102/710
for the Time i’m using a NikonD810A
this camera is very nice to use but pixels are very small…
i’ m considering to buy a ccd camera with bigger size pixel
Atik 11000 with 9 nm pixel or Atik 16200 with 6nm pixel size
the  qhy 128 c is a CMOS with 6nmpixel seems nice also
i will enjoy your advice about that
anyway it will be color camera and not mono camera
because i ve to move to take picture each night
thanks
xordi avatar
The big pixels are really good to have in C8, but the corrected FoV is only size of APS-C so  you must crop a lot in fullframe sensors like in Atik 11000 or in Atik 16200. Atik 4000 fits better, however it is an older type.  I personally use AtikOne6 wit C8 and it is not that bad, but far from optimal. Binnig helps.
Alessio Pariani avatar
Personally I would choose a CCD instead of a CMOS. The QHY128C uses the same sensor used in Nikon D600-610-750. Do you really want another DSLR?
CCD works at 16bits (instead of 14).
Be careful also on the full well capacity. In CMOS you have a wonderful value in tech sheet, but raising the gain the FWC drops and you get everything burnt
go for 16200!!
