Help! 52mm Filter for Crop Sensor
2 replies214 views
URSAMO avatar
Hello Astroheads!
I Currently have a Canon 80D
Just Won a IDAS NBZ Nebula Booster Filter - 52mm.
Wanted to ask how can I use this filter on my setup?
Is there any drawers for Crop Canon 52mm Filter?
Can i put the filter on top of the lens?
My lens is a Canon 135mm F2 - 72mm
The filter is 52
How can i use it??
Is there a 3d printable Mount for 52mm Filters to put on 72mm lenses??
Clear skies! 🙏
kuechlew avatar
Hi, what you're looking for is a so called "step down adapter" or "step down ring" e.g.: Belmalia 8 Step-Down-Ringe Set, Objektiv-Filter-Adapter: 82mm 77mm 72mm 67mm 62mm 58mm 55mm 52mm 49mm: Amazon.de: Elektronik & Foto
Didn't do an extensive search whether you will need to stack multiple step down adapters or if there exists one single piece 72mm to 52mm. Be careful not to accidentially buy a step-up adapter which does just the opposite.
If I calculated properly you're going to lose about 50% light, i.e. about 1 stop.
On a side note I read somewhere that these step down rings could be used as a workaround in case you attach a lens to an astro camera and you can't stop down the lens.
Have fun and clear skies
Wolfgang
SLR lenses with dedicated astrocameras: a good idea?
[pre]Hello everyone. After a few years photographing small things, I decided to capture larger fields. I purchased a Samyang 135 f/2 lens and a Sigma DG HSM 50 mm f/1.4, which I have been able to use with a modified Canon EOS 60D. The problem is that...
Uses Samyang 135mm lens for astrophotography; discusses lens compatibility issues.
Dec 7, 2023
Interference-Style LP (Maybe even enhancement) filters, Fast Short Optics and the Problem with Long Period Variable Stars! Lesson Learned?
The following is something that I just posted with my last image, since it is relevant to the data generated and processed. I am partially reposting here, and changing where appropriate to those who may not see my image Rosette West Widefield - In OS...
Discusses LP filters and their use in astrophotography imaging setups.
Feb 18, 2024
Which dual NB filter is best for F/5? IDAS NBZ-II?
I have been really indecisive between choosing an IDAS NBZ II, an L-Extreme F2, and an Antila ALP-T, for my F/5 Newt and 533mc pro. All three are really good, but I want the best for my needs. The filter I'm looking for has to have these things: ...
Discusses IDAS NBZ filter specifically; relevant to filter application questions.
Mar 17, 2024
Rokinon 135mm Lens issue
Hello AB community. I have been trying to figure out what is going on with my 135mm setup. I'm not sure if this is internal reflections, light leakage, or something else. The imaging train consists of : A ZWO 2600MC pro - ZWO filter drawer to len...
Troubleshoots 135mm lens setup; similar equipment configuration.
Feb 29, 2024
