Mike Butorac avatar
hello!
So 1st light (WO GT 71) and 1st  telescope after starting with Canon DSLR's. I think the stars look a bit squashed and some splotchy background, but Bodes looks OK. Your thoughts?
Star Adventurer, Bortle 7/8 no filters; 77 x 75" (1'36"); 30 each calibration; ASI296MC PRO; APP processed.
kuechlew avatar
Welcome and congratulations. Your first light is way better than my first attempt to image M81, which I don't dare to show here. Maybe you're a bit too aggressive with stretching. It looks like the cigar galaxy is overexposed and so are most of your stars. With a more moderate stretch your stars may show some of their colors and M82 certainly looks better. You may have a look at some other images of M81 and M82 here at astrobin. With your astro cam you may have a chance to capture some of the Ha jet of M82.
Clear skies
Wolfgang
New to using a Full Frame Sensor / 50mm round filters. What kind of vignetting should I expect with an f/5 system?
Hello everyone, Now that I have the AG Optical FA12 (12.5", f/5, fl 1570mm), with a stated corrected field of 50mm, I am trying to make sure I am utilizing as much of that cone of light as possible. My imaging train currently is a little bit wei...
Vignetting concerns relevant to new telescope and sensor setup experience.
Jan 1, 2024
New Camera, new Filterwheel and new Filters. Do the flats look ok?
Good evening fellow astro friends, I recently acquired a touptek 2600mm, toupteks new filter wheel and a set of antlia 4.5 sho filters + their pro lrgb set in 36mm unmounted. i have finally got all the adapters and the time to assemble my new setup. ...
Discusses flat calibration with new camera and filters, directly applicable.
Jan 19, 2024
Please share your thoughts about when the flats should be taken during a session.
I am looking at all the information and different opinions available on the internet on whether flats should be taken after the subs, or that it is ok to take them at the beginning. There seems to be a consensus that it is absolutely imperative to ta...
Calibration procedures directly relevant to author's imaging workflow questions.
Nov 10, 2023
Filter Upgrade Time - Antlia Quad Band?
Hi folks: I've been imaging with from my Bortle 7/8 backyard for a few years now, and I'm starting to wonder if it might be time to consider upgrading the filters I'm using. I use an Optolong L-eXtreme for Ha/OIII targets which I've b...
Filter upgrade considerations for Bortle 7/8 imaging location match.
Dec 9, 2023
Round artifacts on image from Celestron Edge HD 8
EDIT: consensus seems to be this is dust on camera sensor cover, or on reducer, or somewhere in the image train. Solution: Clean, then shoot again and take new flats. If you think it's NOT dust motes, please let me know below. I understand calibr...
Image artifacts troubleshooting relevant to author's splotchy background concern.
Nov 8, 2023
