Codey:
So something like the Edge HD8 wouldn’t be the best choice for next upgrade?
Well, I'm not saying no. It's up to you to decide. As the Celestron are interesting scopes!
It's also great for galaxies, great for planetary imaging. And you can always, at some point, look into putting a "hyperstar" on it. And turn it into a 400mm/F2 scope. It certainly is a scope I'm considering for an upgrade at some point in the future.
I don't have any experience with them, so perhaps others can provide better information on them.
but I can tell that it is quite a step up from the redcat.. not impossible.. but less forgiving than a wide field setup.
Edge8 + 533 here you go, that's a few of the images that people have made with that combination.
So it is certainly something that could work
Things to keep in mind:
- You're going from 250mm to 2032mm (or 1422mm with the reducer)
Meaning polar alignment needs to be spot on, it means guiding needs to be spot on.
- Speaking of the guiding, I don't know what guide scope you're using?
but at those focal lengths, you might want to consider an off-axis-guider.
And speaking of the off-axis-guider but the 120mini might not be sufficient for off axis guiding.
Most recommend a 174MM mini for an off axis guider at that focal length.
(But a 290mm might be fine)- You will be slightly oversampling your images. This occurs when the camera’s pixels are too small for a given scope’s focal length. The incoming light is being spread over too many pixels resulting in a soft and bloated image. + you might need to do longer exposures to get enough light into those pixels and get a good signal to noise ratio.
This also means your seeing conditions (the state of the atmosphere) becomes more important for your imaging.
(you're only slightly oversampling though, so the issues might be manageable)It certainly is an impossible upgrade. Just keep in mind that might just be a bit of learning curve, and there are more things to consider, it's not always as simple as slapping a camera onto a new scope and start imaging. Others with more experience with those kinds of focal lengths might be able to help you better though.
